| quote | Originally posted by DanDamage:
Ok thanks on the PS advice I also suspected the same. The car seems to have been sitting for years in a hot s. Fla yard I'm up in the Appillachian mts now, I covered up so much exposed wires I almost used a full new roll and the old plastic covers were so brittle they'd break upon touching them. The car was not leaking when I was in Florida it only has 102k when I bought it, when I brought it up here in the mountains it started leaking crazily just weeks later where I had to put about a half a quart a week I believe it was, now it's suddenly mysteriously stopped which makes me think something with the oil filter , I hope. On a good note though the power steering works now in the rain.
Anyone know if I can pressure clean the aluminum 5 spoke rims before repainting them black? I have five rims only one has remained black the other four that were on the car exterior are all rust colored
If the wheels are alum. the rust color is brake pad dust and rotor material.
I'd have them sand blasted before you repaint if a good cleaning does not remove the brake dust/dirt from the wheels.
The oil leak. do an oil change with the high mileage oil it has stuff in it to help old seals, and gaskets, reseal. not ideal but works.
Can't help on the p/s. but is the motor under the dash,? or near the rack under the hood?
If under the dash, check to see if your windshield is leaking when it rains, Also check that the heater core isn't leaking, yes the core is most times on the pass side ,and the steering on drivers side, but the bcm (body control module) and it's wiring can be anywhere.
one last thing, if this car has a sunroof, the drain hose(plastic) most likely is done for from the heat. and the sunroof can drain the water down the front of the roof and a pillars, dash/etc. as most newer vehicle the headlinder is coated boarding or plastic with fabric over that, the water will not show on the headliner.
replacing said drain hose is, well, fun.
[This message has been edited by E.Furgal (edited 10-30-2019).]
