  Totally O/T
  Best Source For New Replacement Engine For My Riding Mower ?
Best Source For New Replacement Engine For My Riding Mower ? by cliffw
Started on: 05-06-2019 01:03 PM
Replies: 11 (204 views)
Last post by: cliffw on 05-06-2019 11:19 PM
cliffw
Total ratings: 294
Report this Post05-06-2019 01:03 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
After looking at new mowers, the prices spiked, when all you get is bling for your lawn care tools.
I want a new engine.
Briggs and Stratten 17.5 hp.
Total ratings: 297
Report this Post05-06-2019 02:03 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any LS1's in that junkyard you were talking about ?
Seems like a perfect time, and an LS fits in ANYTHING.......with enough work...
Hell, go for gold. Mopar 383 with a 727 behind it. .....NOW, you are cutting grass.
[This message has been edited by MidEngineManiac (edited 05-06-2019).]
mike-ohio
Report this Post05-06-2019 02:19 PM Click Here to See the Profile for mike-ohioClick Here to visit mike-ohio's HomePageSend a Private Message to mike-ohioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Harbor freight has a 22hp Preadator engine for $799. They go on sale for less.
Not a Briggs and Stratton, but may people use them for swaps.
You could always look for a used one on craigslist. Many times the mower decks rot away before the engines fail.
Total ratings: 205
Report this Post05-06-2019 02:33 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Small Engine Warehouse
Muncie Indiana
They've been in business for decades.
Steel
Report this Post05-06-2019 03:02 PM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 297
Report this Post05-06-2019 03:27 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Joking aside Cliff, change it out for a Kohler...You CANT kill that thing. My old Aierens ran hot or cold, step daughter ran it out of oil, cut grass, plow snow, haul wood..rain, sleet...It didnt matter with that thing. Jump on turn the key and you are going. If the battery is dead it can be jump started with a 5-foot push.
I had the back 2/3rd of that tractor in the swamp pulling out a log...YUP, it just keeps going.
Total ratings: 441
Report this Post05-06-2019 05:05 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Old Kohlers were pretty good. The newer ones not so much...I've seen lots of dead ones on mowers, bigger rear-tine tillers and lawn/garden tractors.
Loved to see a Kohler powered unit come in with noisy internals..quick sell of a new engine as the labor to rebuild cost more than the replacement engine. Most upgrade from Kohler to Honda, tho some went with B&D.
Yep, and while most B&D engines are readily available as OEM replacement, decks are much more difficult to find.
Lawn tractors/riders:
eng= 1/3 of the unit's cost..
deck=1/3 of unit cost ..
frame and drive train= the other 1/3.
[This message has been edited by maryjane (edited 05-06-2019).]
cliffw
Total ratings: 294
Report this Post05-06-2019 05:56 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
For zhits and giggles, I checked Amazon. Surprise ! They have what I need.
This one, for $505.51.
Not to mention, a trip to the small engine repair shop, a cost of $100.00 should be expected. Around here it includes a two week (at least) wait time and who knows what employee might work on it.
My other engine ran fine except the crankcase pressure relief valve (lowers compression for start up) does not work. An internal fix at the bottom of the crankshaft.
I wouldn't mind going Honda but I have no idea what would fit / work.
Thanks all.
[This message has been edited by cliffw (edited 05-06-2019).]
Total ratings: 205
Report this Post05-06-2019 07:16 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
SEW has Honda conversions for many small engine applications.
Total ratings: 154
Report this Post05-06-2019 08:10 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Briggs-Stratton OHV engines have historically had a problem with the rocker arms coming loose. My first engine got replaced because it acted like it was out of time, meaning the flywheel had slipped on the top of the crankshaft. I bought a replacement at Grainger.
Later, that one did the same thing. When I went to an individual who repairs small engines, looking for a used mower, he told me what the problem was. A valve adjustment did the trick. Over the course of the time I had it, it had to have the valves adjusted several times because the rockers would come loose. Eventually, it slung a rod.
cliffw
Total ratings: 294
Report this Post05-06-2019 11:12 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't believe every thing I think. I don't believe you are right.
A valve adjustment doesn't mean the rocker arms "came loose". I believe they wore loose. I have seem in many factory service manuals that, a valve adjustment on those types of engines (mechanical lifters vs hydraulic), is an important scheduled maintenance task. My motorcycle, my VW bug, my riding mower.
Adjusting mechanical valves is as easy to do as an oil change. The first three times might be scary and difficult. After that, you could make money doing it on the side, if you wanted to. I look at mine often, even if it is running good. As I tend to whatever else in scheduled maintenance. (Usually for me, when it is not running good, )
cliffw
Total ratings: 294
Report this Post05-06-2019 11:19 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
cliffw
Member since Jun 2003
Look at you ! Been here since 2002. 11202 posts. 148 ratings.
Not on negative rating ? No red marks on your permanent record ?
C'mon man ! Get with the program, .
Congratulations. I have never seen such as you.
