760
Ti is a "problem" if you need fast GPU... Example: See
https://www.techpowerup.com...gtx-760-ti-oem.c2491Any Ti version is a lower end unit and while can play games etc is not made to be a "best" product.
I have 750 Ti and works very well for most things but it still a "low end" card all the same.
DL HWMonitor from CPUid and run that while you run whatever.
Or find other things to monitor the system other that BS "bench mark" software. (If Win7... find "GPU meter" gadget to monitor the vid card.)
I doubt you find most of the thing you run won't push CPU or GPU even close to 90%+ utilization. I can't even push to 95% utilization in many FurMark etc tests. Most time the vid card and most everything else is at idle or close to that. (AMD Phenom Black FX-8370 and 12GB DDR3 RAM)
Check MoBo "BIOS" too. If you have a "turbo"/"Black" AMD CPU and BIOS is not setup to run turbo then system won't run at top speeds often even with AMD software.
Even then, most GPU will barf on most Displays causing Frame Tearing etc. IOW Doesn't matter when any Bench Mark software "claims" the system can generate 60 100 and more FPS and Displays connected to them only handles 30-50 FPS.
