After I move (no more than a couple of months), I'm thinking about replacing my desktop and older (but decent) laptop w/a single, higher end laptop. This needs to work as a desktop replacement. It needs to be compatible w/some sort of quick connect dock (similar to this). I want to be able to plug in 2 monitors, k/b, mouse, hot swap dock and/or external HDDs/SSDs, etc and be able to just pop the laptop out when I want to take it w/me.
I don't game but I DO want something fairly powerful so I don't feel the need to upgrade every year. A larger, higher res screen would be preferable (4K is NOT necessary). I need to be able to upgrade the HDD/SSD and RAM. I'd prefer a "name brand" as they tend to have more backing than the off brands. A fast processor is also a must although I'm not picky about brand. Both Intel and AMD have their pros and cons. I'll probably run Win7 or 10, if it matters. Since it will run 2 monitors, a dedicated GPU is probably a plus although I might be able to get by w/o it. (I'll watch quite a bit of HD (but NOT 4K) video (TV/movies) on my monitors.) Quality or availability of a web cam means nothing. DVD burner is also a must. Plenty of USB 3 ports are also a plus.
I don't need a top of the line, $3000 laptop. Gently used is fine. I'd like to spend less than $1000, if possible including a dock and decent specs.
The last laptop I bought was used from a wonderful member here. It's worked well but it's time to upgrade. If anybody has a laptop that would meet my needs they want to sell, PM me. If not, what brands and/or models would you guys suggest?
I run my gaming laptop like you describe, but found a docking station isn't needed. Just an extra charger.
I keep it on a shelf to the left of my desk, and HDMI, keyboard, mouse, printer, and power cables are run thru an adell clamp on the side of the shelf to keep them handy and where I need them. It takes me less than 30 seconds to plug everything in, or unplug and grab it when I want to go with it.
Spare charger stays in the laptop bag so I always have it on the go.
BTW, I wouldnt go smaller than a 32" for a gaming monitor. I've got a 40" Samsung smart TV I picked up at a pawn shop, and once you play on a big screen you will thank yourself for getting it.
[This message has been edited by MidEngineManiac (edited 10-07-2018).]
Thanks, MEM. I don't game unless you count things like Tetris. I've got a couple of 24" monitors. Once they die, I'll find another pair of 24" (or larger) monitors that are on sale. I have no need for extra large monitors. I'd prefer a dock although I wouldn't rule out a laptop w/o one for the right price/specs.
Have you ever checked out a place called Tiger Direct?
I have bought a few things from them over the years and never had a problem. They have some good deals on a regular basis, you just have to keep looking in often to catch them.
Thanks. I've looked there as well as Newegg. I'm thinking I can get a better deal buying used.
I found a Lenovo at a pawn shop that has a ton of software and applications. It is a high end laptop and I like it. It cost $325 and has 16gb memory, a large HD, a ton of ports I'll never use and a couple apps I have fun with. Maybe I am lucky. I drove 60 miles to Springfield, OR to get it but I think it was worth it. I still like my Dell, though.
Keep in mind, maney of the new laptops have no CD\DVD drive, but an external USB DVD drive can be used. Always check the weight of the laptop...some are freaking heavy. Alianware has good rateings, its peomoted as a gameing laptop, even though your probubley not going to use it for gameing
[This message has been edited by James Bond 007 (edited 11-29-2018).]
Thanks, Mr. Bond. I'm not worried about a CD/DVD drive. As little as I would use one, an external would work well. I'll see if I can find some used Alienwares.
Ive had good luck with 17" Gateway/Acer laptops. Im still using the original battery from like 6 years ago in one. Another one died this past summer that was 10+ years old. Motherboard went out. Your going to laugh, but I started years ago only buying laptops on Home Shopping Channel. The ones ive gotten were half of the stores prices, came with other benefits like 5 years support, 2 year warranties, and $1000+ dollars of pre loaded software programs...most of which I actually even use. I wont even consider buying one in a store anymore. Go to HSN.com and just look...cant hurt. While on live tv, even those prices are substantially reduced.
