That was already loose, he tightened the strap together then just pulled it by hand. Im callin bs. Thos f#ckers are always on there tight! I was watching for what he was going to tie the ratchet too but he just made a loop and pulled a tiny bit
Worked fine for me on my V8 Fiero a couple of times. Thats how I changed the belt on the water pump. I didnt even have it running. Just started the belt as far as it would go and turned the engine a few degrees by hand and belt popped right on every time.
Where are the videos with the unibrow guy who is always wrecking himself in the name of something that really isn't funny?
I wish belt changes went that smoothly. I had hell of a time on my LQ1 (screw that tensioner), Mazda Protege (had to take off one belt to get to the other and broke the A/C Shraeder valve) and my 2.8 Fiero belt just never seemed tight enough. Autozone for a while were giving alternators with the wrong pully and that was another bit of grief.
Aw man awesome awesome videos. I had 6 bugs, never saw that belt trick. Using starting fluid w a lit stoge in the mouth is just dumbbbb. Seen guys do the starting fluid trick. Never w that much fluid jeez.
Last videos the best yes now ve have sticking drum brake tight very. Need to make lubricate vit ze finish hummer. I make beating vit hammer finish on drum brake vile i poop pants mine. Look at poop on ze floor now. Drum brake isz very loose now yes? Yes now veel is free n no more braking from zis veel rear. Zank you for vatching video, I hope you make useful information car.
