| quote | Originally posted by hnthomps: Consumer Cellular is a GSM phone that uses AT&T towers for broadcast/reception. I got one for my father in law a few years ago and it worked well when he wanted to use it. |
Depend on where you are at any given time CC uses Tmobil too and switches networks from ATT to Tmobil and back.
I
Hate CC. Tried several phones and all drop signal a lot. Just go into any building and drop signal only a few feet in to many because used ATT or Tmobil.
CC Phones offered are very few and most are junk.
CC "bring you own device" simple does not work w/ most phones because most are SIM Locked phones. They only tell you in very small print in ads or when you call CC support because phone won't work.
2 quick Examples:
If you have Verizon will take SIMs for roaming and Verizon unlock the slot, SIM unlock phones always default to Verizon network and will try to connect to them. Many Verizon phones are made so Can't unlock SIMs permanently and will lock every day. Many lock again in hours.
If you find Tmobil phones, CC sims often works only to connect to Tmobil towers even when SIM slot is unlock. ATT phones often only see ATT towers.
Sprint Tmobil and ATT are networks that most others use, Boost Cricket CC etc, and often are lower speeds too.
Verizon is expensive but I got far less problems w/ them and very few areas when I had no signal even inside buildings.
Note: Comcast Mobil uses Home and other Comcast Hotspots to connect voice calls and data.
When phones can't see them then currently uses Verizon.
