| quote | Originally posted by jmclemore:
Thus confirming my need to ask for information.
Thank you for the feedback. How well do you know the citizen L32 ? And would you mind me contacting you directly?
They are having trouble getting it to run and that would be a key selling point for getting the job. I have been told a little bit about the problem and could be related to a homing issue. Between the other machinist, maint and management , it's clear they are stumped....
Edit spelling conflic between eyed and thumbs....
I know just enough about running a CNC screw machine to be dangerous, so I'm not the best guy to counsel you.
That said, I have observed that a CNC machine that won't home back to zero has often been caused by a hardware / equipment failure and not a software or operator problem.
This is also often the case with machines that have been moved and reinstalled somewhere and were not "parked and locked", (my term), correctly before moving them.
The quickest and surest way to make certain that the machine is functioning properly is to simply contact the OEM support rep. and have them look it over.
That is also usually the least expensive route to take rather that burning up company time and money trying to guess the problem.
If you really want the job running those machines, then my suggestion is for you to latch onto that OEM rep the moment he hits your door and don't let go for a nanosecond. Take him to lunch and make sure you have his number on your cell phone.
You can very quickly put yourself into "expert" status by prying every scrap of knowledge, hint and tip you can out of him.
The other guy that left had to get his "expert" knowledge somewhere too.
[This message has been edited by randye (edited 10-29-2017).]
