TV cancells channel scan? by MidEngineManiac
Started on : 06-20-2017 07:10 PM
Replies : 8 (187 views)
Last post by : spark1 on 06-23-2017 01:31 AM
Jun 20th, 2017
MidEngineManiac Member Posts: 29566 From: Some unacceptable view Registered: Feb 2007
Total ratings: 297
Ive got a Sanyo tv, run on a set of rabbit ears. Picked up a 10dB signal amplifier today, and tried to run a channel scan to see if it gives me a few extra. The tv gets about 20% done the scan, then cancells itself. Dont matter if I set it to analog, digital or all signals it does the same thing. The 2 it finds before cancelling are now amazingly clear, but I would like to finish to get the rest of them. Any ideas on what I can try, besides hitting it with a hammer?
07:10 PM
maryjane Member Posts: 69649 From: Copperas Cove Texas Registered: Apr 2001
MadMark Member Posts: 2935 From: Owosso, Michigan, USA Registered: Feb 2010
On most TV's after you scan you can also go and manually add or delete channels. So you might try that.
07:53 PM
WBailey1041 Member Posts: 2424 From: 60606 Registered: Dec 2003
quote Originally posted by MadMark: On most TV's after you scan you can also go and manually add or delete channels. So you might try that.
Yep, go here,
http://yourfreedtv.com/ find local channels and do it MANUALLY! You lazy snow bum!
08:18 PM
spark1 Member Posts: 11159 From: Benton County, OR Registered: Dec 2002
Maybe you need a 10 dB pad on your amp output.
10:54 PM
Jun 21st, 2017
E.Furgal Member Posts: 11708 From: LAND OF CONFUSION Registered: Mar 2012
Total ratings: 278
What is the ohm rate of that signal booster, and does it match the tv antenna connection..
07:08 AM
rogergarrison Member Posts: 49601 From: A Western Caribbean Island/ Columbus, Ohio Registered: Apr 99
Just for giggles, try reorienting the antenna and scanning again. Only times ive seen them stop adding channels automatically is because it didnt find them. Or like said, just enter them manually. Ive got several tvs set to get over the air thru antennas. Some just dont get some channels others do either because of different antennas or subpar tuners.
02:56 PM
Total ratings: 297
Im off tomorrow so will have time to play around with it.
LOL, the antenna is a home built job made from this type of lamp.
http://www.ebay.co.uk/bhp/halogen-desk-lamp NO idea on on any of the specs as an antenna. Transformer blew so I gutted it and wired a coax cable to the steel arms, then put a couple 2"x2" L-brackets on top where the lamp housing was.
04:19 PM
Jun 23rd, 2017
OMG
01:31 AM
