Click here to visit the donation page | View all sponsors
  Totally O/T
  Swapping parts from a 96 Ford Explorer to a 91 Ford Explorer??
Swapping parts from a 96 Ford Explorer to a 91 Ford Explorer?? by twofatguys
Started on: 05-24-2012 10:06 PM
Replies: 6 (91 views)
Last post by: twofatguys on 05-25-2012 11:34 AM
twofatguys
Total ratings: 228
05-24-2012 10:06 PM Click Here to See the Profile for twofatguysClick Here to Email twofatguysSend a Private Message to twofatguysEdit/Delete MessageReply w/QuoteDirect Link to This Post
My brother wrecked his Explorer yesterday, he clipped a trailer with his rear axle, and tore the rear end out.
I have not seen it, I don't know what it looks like, or exactly what he did.
He just called me and asked what problems he would run into if he bought a 96 for the rear axle. It's the same Motor/Transmission, but a newer body style and the interior is destroyed.
He also asked about using the transmission as his four wheel drive hasn't worked since he got his, something about the transfer case.
I said I didn't know, but would ask on here and relay what was said to him.
I figure the 96 will be similar, he said they look identical.
Thanks in advance,
Brad
Tony Kania
Total ratings: 224
05-24-2012 10:16 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rear end... Exploder, Ranger, Stang, all same 8.8. Gearing may be different. Not 100% on tranny/transfer case though.
The OG white guy
$Rich$
Total ratings: 392
05-24-2012 10:28 PM Click Here to See the Profile for $Rich$Click Here to Email $Rich$Send a Private Message to $Rich$Edit/Delete MessageReply w/QuoteDirect Link to This Post
96 was a 2nd gen they might not be as similar as you might expect.
i have a 99 EB exploder AWD 5.0
here is a good forum
http://www.explorerforum.com/forums/
Total ratings: 412
05-24-2012 11:24 PM Click Here to See the Profile for RaydarClick Here to Email RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or you can go to http://www.car-part.com/
Enter the vehicle's info. It'll give you a list of available parts from all years that will work.
A quick glance seems to indicate that they are only compatible up to 1994. I didn't see anything newer.
Tstang429
05-25-2012 01:12 AM Click Here to See the Profile for Tstang429Send a Private Message to Tstang429Edit/Delete MessageReply w/QuoteDirect Link to This Post
Transmission and transfer case are completely different. Your also talking obd2 to eec computers two different worlds. If he ripped the rear end out. I would also be very worried about the drive shaft. if i remember right the drive shaft is bolted on both sides with a center slip joint. Before buying another I would see if he just sheared the u bolts and twisted it. At the trans shop we had a 95 f250 city plow truck that they curbed hard and twisted the front axle almost 45 degrees. a few cuts on the mounts and some new shocks it was back on the road. The city was happy we got that old truck fixed for cheap but the employees weren't they were trying to kill it.
masospaghetti
05-25-2012 09:30 AM Click Here to See the Profile for masospaghettiClick Here to Email masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would expect the rear ends to be interchangeable but the transmission/transfer case will not be a direct swap. The transmissions are similar but not the same. The transfer cases are a different model but I think it will work if you also take the front driveshaft from the 96.
twofatguys
Total ratings: 228
05-25-2012 11:34 AM Click Here to See the Profile for twofatguysClick Here to Email twofatguysSend a Private Message to twofatguysEdit/Delete MessageReply w/QuoteDirect Link to This Post
Texting him now.
"OK, What I am getting from the Forum. Before you get a replacement truck make sure you can't just fix yours. Look and see if you can just replace the Ubolts, and drive yours.
Also check the drive shaft and make sure it's not damaged. Rear Axle should be close enough on the 96, the rest is different.
Changing the transfer case you will likely have to change the front axle as well. Probably some wiring. Would be simpler to just put a new interior in the 96. "
Thanks guys. +'s all around.
Brad
