  The Mall
  87 SE (notchback) Caddy 4.9 Project Car
87 SE (notchback) Caddy 4.9 Project Car by frige
Started on: 09-17-2023 02:51 PM
Replies: 0 (361 views)
Last post by: frige on 09-17-2023 02:51 PM
frige
Report this Post09-17-2023 02:51 PM Click Here to See the Profile for frigeSend a Private Message to frigeEdit/Delete MessageReply w/QuoteDirect Link to This Post
87 auto SE blue/grey - 93 Deville 4.9L/4T60E
257k miles
Located in Reston VA
Does not run…
Many miles, but the interior is very clean.
Car has been garaged since I started the project.
I had it running (7/2006), and then I started to redo the fuel lines with flexible line and proper an-fittings. Fuel lines need to be completed.
I imagine the gas tank will have to be cleaned.
Toyota wheels (drilled to fit fiero/neon).
Battery relocated to front under spare (needs new battery)
Engine cradle was stripped and por-15’d, new bushings.
Coilover suspension on back.
Most of the brake system has been replaced (lines, calipers).
Oil filter holder has been drilled out (no oil cooler needed).
Passkey has been programmed out.
Custom AC line (system will need to be filled - and I dont think i wired it up correctly)
Key is stuck in the ignition.
The front trunk wont latch for some reason - that’s new to me.
A 2.5 crossover pipe was made so the exhaust comes off the engine like the fiero.
I have 2.5 inch spintec exhaust that has not been attached - i was intending on having a shop make it fit right. It is routed like the fiero, with the cat in front.
Not sure I have the muffler tips, but I do have square camero tips.
The air filter was never finalized. I have the caddy snout, and something from a yukon with K&N that fits.
Manuals and notes.
Clean/clear title
$3000/BO
