Well they may be obsolete but they do work and fit 16" wheels and are really cheap. My total cost of 4 rotors was $110. I made the adapters myself for $5 each. Oh and one more thing with the drop ball joints and the caliper brackets you may need to lengthen your front brake lines by 1". So there's another $60.
With my original 88 brakes it was almost impossible to lock up the brakes intentionally and the pedal force was higher. Now they can be locked up and the pedal effort is lower. The 13" rotors would give even more leverage, lowering the pedal force for sure.
The brackets are simple. Get some 3/8" x 2" flat stock.
Mark out a rectangle of 20mm x 67mm in the center of the flat stock
Drill 2 holes for 12x1.75 pilot and countersink (finding a 1" countersink was difficult, I re-cut a 1" HSS drill).
Drill other 2 holes to 12mm.
Round off the corners and relieve the top and bottom to avoid the calipers
Clean up rough edges
Get 2 x 12x1.75 FH x 25mm 10.9 or stronger allen head or torx bolts per wheel.
Mount the brackets in the old caliper position. Torque to 70 Ft-Lb.
Mount the calipers to the bracket. Torque to 70 Ft-Lb.
The calipers are a bit more difficult because the centering ringd don't exist in the exact size needed. Not that the hub diameter has two measurements. the diameter of the hub to mount the disc is larger than the diameter where the wheel mounts. And the discs are not 71mm exactly.
Find some spacer rings for the discs 70.5mm to hub 57. mm. to center the disc (finally found some 71 x 57 from autoanything.com and needed to trim them a bit to fit).
Measure and drill the rotors for 100mm PCD x 5 and carefully drill for 12mm (or a little larger since getting the hole placement exact was challenging for me).
Install the parts and make certain the rings do not prevent the rotors from seating.
