  The Mall
  Need wheel lock socket
Need wheel lock socket by LoveBirds
Started on: 07-29-2020 06:47 AM
Replies: 10 (272 views)
Last post by: johnyrottin on 08-01-2020 08:57 AM
LoveBirds
Report this Post07-29-2020 06:47 AM Click Here to See the Profile for LoveBirdsSend a Private Message to LoveBirdsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone have the key / socket to remove the lock lug nut?
Need it before Saturday, yikes!
[This message has been edited by LoveBirds (edited 07-29-2020).]
sourmash
Total ratings: 50
Report this Post07-29-2020 08:58 AM Click Here to See the Profile for sourmashSend a Private Message to sourmashEdit/Delete MessageReply w/QuoteDirect Link to This Post
You'll probably have to buy a standard socket and drive it on the nut. I think I used a 6 sided socket. In the interim you can dab trans fluid on the threaded area to soak to make it move more freely.
I've also used one of the tuner six tab keys and ground some of the tabs off. In my case I left 2 tabs, one at 12 o'clock and one at 6. It worked on 2-3 of the nuts but not one of them.
Lambo nut
Total ratings: 257
Report this Post07-29-2020 09:13 AM Click Here to See the Profile for Lambo nutSend a Private Message to Lambo nutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most tire shops will have the tools to remove that.
Warlordsix
Report this Post07-29-2020 09:46 AM Click Here to See the Profile for WarlordsixSend a Private Message to WarlordsixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Use a lug nut removal tool.....I've used one for 4 locking lug nuts, and it took each one off without trouble. Easy.
https://shop.advanceautopar..._medium=cpc&utm_camp aign=b_pla_all_hand%2Fspecialty%2Ftools_hand%2Ftools_gen_gen_all_pros_aap_us_all&utm_term=4580634168436967&utm_content=Bing_PLA_Hand%20%26%20Specialty%20Tools_Hand%20Tools_Specialty%20Measuring%2Fassembly%20Tools&gclid=CMalwo_M8uoCFTwHiAkdRhINRQ&gclsrc=ds
'87 Fiero 4.9 5-speed
LoveBirds
Report this Post07-29-2020 02:01 PM Click Here to See the Profile for LoveBirdsSend a Private Message to LoveBirdsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok I was looking at those tools yesterday at the local parts store, didn’t seem like it would work but since you had success I’m going to grab it and give it a go.
Since car is wrecked I need to possibly remove wheels and take calipers off to free up wheels to get on a trailer. So taking it to a tire shop isn’t an option.
thelinsells
Report this Post07-29-2020 07:43 PM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you go to almost any tire store , they have a selection of these tools .
fst100
Report this Post07-30-2020 05:59 AM Click Here to See the Profile for fst100Send a Private Message to fst100Edit/Delete MessageReply w/QuoteDirect Link to This Post
like sourmash suggested, get a socket that you'd prolly have no use anymore that fits just snug on there and hammer the socket onto it then use a breaker bar or impact wrench to get it off. prolly toss both the nut and socket afterwards since it'll be a ***** to separate them. I used this technique on locking lug nuts on my jeep which used 19mm and I used a 12 bolt standard that was about the same size that was tight fit but hammered it on to get the nut off.
edit-
I used method 2 in the vid below
youtube vid
[This message has been edited by fst100 (edited 07-30-2020).]
sourmash
Total ratings: 50
Report this Post07-30-2020 05:44 PM Click Here to See the Profile for sourmashSend a Private Message to sourmashEdit/Delete MessageReply w/QuoteDirect Link to This Post
I reused the same socket on several lug nuts. Once it breaks free leave the lug loose but still in the hub and work the socket off. Just driving the socket on far enough in the first place is key too. Don't drive it home.
David Riedle
Report this Post07-30-2020 06:43 PM Click Here to See the Profile for David RiedleSend a Private Message to David RiedleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have always welded a nut on the wheel nut.
Works well.
Dave
Report this Post07-31-2020 05:22 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
We have two or three Fiero OEM wheel lock keys w lug nuts in the shop but there are like 6 different versions. If you need a wheel lock socket its almost impossible to tell which one might fit without having the car and the keyed sockets in the same place.
johnyrottin
Total ratings: 85
Report this Post08-01-2020 08:57 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Start soaking those lugs in tiny bit of tranny fluid. They are a ***** to get off once they rust up.
