  The Mall
  Wanting to buy: Holley intake manifold for iron duke
Wanting to buy: Holley intake manifold for iron duke by Indy-453
Started on: 07-27-2020 01:33 AM
Replies: 5 (265 views)
Last post by: Indy-453 on 08-19-2020 07:38 PM
Indy-453
Report this Post07-27-2020 01:33 AM Click Here to See the Profile for Indy-453Send a Private Message to Indy-453Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello,
I am looking for a Holley manifold for an iron duke. Shipping would be to Calgary, Canada.
Thanks.
Report this Post07-27-2020 10:00 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you decide to use that manifold, I believe that it will only accept the larger Holly throttle body. It should enable gaining some horsepower but those two items are difficult to find. The big question is: will the gain justify the investment?
Indy-453
Report this Post07-29-2020 01:39 AM Click Here to See the Profile for Indy-453Send a Private Message to Indy-453Edit/Delete MessageReply w/QuoteDirect Link to This Post
I know the upgrade parts are perhaps controversial when V6 swaps are common. I am trying to keep the car looking as stock as possible to the casual viewer, while eking out what power can be had. Hiding a better flowing manifold under the air cleaner helps achieve that. I already have obtained a NOS TBI unit, just need the manifold.
Report this Post07-29-2020 02:14 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many other GM automobiles of that era had the Iron Duke engine. If you cannot find the Holley unit, I would investigate which year manifold might flow the best, bolt up and accept the larger Holley throttle body. IMO, the larger Holly throttle body itself is the main power adder and you can always port to smooth out the flow.
lyleap-gmc
Report this Post08-19-2020 05:50 PM Click Here to See the Profile for lyleap-gmcSend a Private Message to lyleap-gmcEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an Iron Duke that I just pulled out. It has the Holley throttle body. How does one identify the Holley manifold?
Indy-453
Report this Post08-19-2020 07:38 PM Click Here to See the Profile for Indy-453Send a Private Message to Indy-453Edit/Delete MessageReply w/QuoteDirect Link to This Post
The clearest tell is it has Holley cast into the side of it.
There's some pictures mid way down the thread in this link: https://www.fiero.nl/forum/Forum4/HTML/074980.html
The port for the TBI unit is also bigger on these manifolds.
