  The Mall
  FS: 12” corvette rotor upgrade kit for 84-87 with 88 Calipers
FS: 12” corvette rotor upgrade kit for 84-87 with 88 Calipers by Fiero Tom
Started on: 05-18-2020 08:47 AM
Replies: 5 (497 views)
Last post by: Fiero Tom on 06-18-2020 03:54 PM
Fiero Tom
Report this Post05-18-2020 08:47 AM Click Here to See the Profile for Fiero TomSend a Private Message to Fiero TomEdit/Delete MessageReply w/QuoteDirect Link to This Post
S O L D *******
Complete used kit (minus front hubs) to install 88-95 C4 12" rotors and 88 Fiero calipers on your 84-87 fiero. Every thing is in working order and is ready to bolt on and go. You will need 16" wheels at the minimum, this brake combination won’t fit under 14” or 15” rims. The fronts are a bolt on and will require a hub made to install the new rotor. When you install the rear calipers the Threaded holes that hold the bracket to the knuckle will need to be drilled out and tapped with a M12x1.75 tap, I will include the required drill bit and Tap.
I’m asking $350 shipped in lower 48 states.
List of very good used parts included:
4 x Front ‘88 calipers with brake pads installed (fitted with ‘speed bleeder’ bleeder screws)
8 x Caliper Bolts
4 x Caliper Adapters (plus attachment bolts)
2 x Front ‘88 Hydraulic Hose
2 x Front rotors with centering rings (drilled to Fiero 5x100 bolt pattern)
2 x Rear rotors with centering rings (drilled to Fiero 5x100 bolt pattern)
Brake installed behind 18” wheels .....
[This message has been edited by Fiero Tom (edited 06-18-2020).]
Fiero Tom
Report this Post05-25-2020 08:38 AM Click Here to See the Profile for Fiero TomSend a Private Message to Fiero TomEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump and price reduction ...... $350 shipped.
When I assembled this brake upgrade I used RAYBESTOS calipers from RockAuto and Centric rotors from TireRack so you’re guaranteed years of trouble free service from this package.
Biggest_of_A
Report this Post05-25-2020 10:56 AM Click Here to See the Profile for Biggest_of_ASend a Private Message to Biggest_of_AEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Tom,
Would I be able to keep the e-brake with this set-up? Presently, have an 85 SE and the brakes Including the parking brake are in good repair but stock configuration.
I have no issues with picking up a set of the front hubs.
Best,
BA
Fiero Tom
Report this Post05-25-2020 11:47 AM Click Here to See the Profile for Fiero TomSend a Private Message to Fiero TomEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Biggest_of_A:
Hi Tom,
Best,
BA
You would have to purchase a set of rear ‘88 calipers to have a working parking brake.
Fiero Tom
Report this Post06-05-2020 11:46 AM Click Here to See the Profile for Fiero TomSend a Private Message to Fiero TomEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump ... anyone interested
Fiero Tom
Report this Post06-18-2020 03:54 PM Click Here to See the Profile for Fiero TomSend a Private Message to Fiero TomEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
