  The Mall
  Big Strut Bolts for 88's equipped with rear sway bar
Big Strut Bolts for 88's equipped with rear sway bar by Rare87GT
Started on: 01-03-2020 09:13 AM
Replies: 5 (178 views)
Last post by: Rare87GT on 01-03-2020 03:11 PM
Rare87GT
Total ratings: 173
Report this Post01-03-2020 09:13 AM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just bought a rear sway bar from a Forum member but I may need to source the longer strut bolts for an 88 that had a sway bar. Does anyone have any older parts or maybe even a parts car that the rear sway bar came off of?
Please let me know.
Thanks,
Amir
Best 1/4: 11.7 @ 115mph
Best 60ft: 1.60
hnthomps
Total ratings: 51
Report this Post01-03-2020 10:51 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you are talking about the end links, Rodney Dickman sold them a few years ago and likely still does.
http://rodneydickman.com
Nelson
qwikgta
Total ratings: 84
Report this Post01-03-2020 10:58 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its been a long, long time, but i don't think i needed different bolts when I put a rear sway bar on my 88 coupe. I think i just bolted it up using the same 88 coupe bolts that were on the car to begin with. One tip, make sure you have left/right figured out b/c i put them on backwards also make sure you put the sway bar on the correct way, i've also put it on upside down.
Rob
Rare87GT
Total ratings: 173
Report this Post01-03-2020 11:40 AM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rob
I will take a look once I get ready to install it. I didn't realize I needed one to begin with but forgot the Coupe's don't have the rear sway bar factory. I just got the brackets re-made by a Forum member so I have a brand new pair. The sway bar is coming soon and then I will just need some hardware to install it. I'll keep you posted. Do you have any good pics of yours when you installed it, etc so I make sure I put it on correctly? Lol.
Thanks,
Amir
[This message has been edited by Rare87GT (edited 01-03-2020).]
cvxjet
Report this Post01-03-2020 12:36 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just used the bolts that were on my 85 when I swapped in the 88 subframe/suspension- they were long enough....You only need one to two threads past the nut.
Rare87GT
Total ratings: 173
Report this Post01-03-2020 03:11 PM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay cool. Just making sure. I didn't realize I needed some many different brackets, etc to make this work on a 88 Coupe.
