In addition to my standard restoration service, I can restore tail lights using body color instead of black. Your refurbished tail lights will be the same color as the exterior paint of your car (with obvious exception of the clear areas for turn signal, brake light and P O N T I A C lettering).
The process is as follows:
• complete disassembly and cleaning of all components.
• polishing of the clear inner lenses.
• prep the outer surface of the lenses with wet/dry sandpaper.
• apply 1/8" striping tape around the large lens opening (turn signal, brake light area) and also each letter of P O N T I A C that are back lit in red.
• spray a thin coat of paint on the lenses.
• remove all taping and then lightly sand the painted areas to reduce the paint edges.
• spray the lenses with two part professional grade clear coat. Cures hard as a rock.
• final sand with 3000 grit and machine polish for a very shiny, clear surface.
• reassemble the components using black weather-strip adhesive.
Here's how this will work:
- send me a PM and we'll swap contact info.
- I will need to know the color paint that you want on your lenses. Either the factory paint code or description so that I can match the color.
- ship your tail lamps or lenses to me (you'll save money on shipping by just sending me the lenses) ... that's where all the work is done anyway. Here's a link on how to separate the lenses from the housing if you want to go that route:
https://www.fiero.nl/forum/Forum9/HTML/000042.html- use good packaging as I'll be sending the completed lenses back to you in the same packaging.
- when I receive them I will send you a confirmation message along with any issues that I find ... cracks, deep gouges, factory flaws (yes, I've seen several ). This is to ensure that we both know any limitations prior to my beginning work.
- I may be able to repair some cracks in the lenses ... particularly when they're confined to the black area of the lens. I use a very fine viscosity super glue, but if the crack is too fine, or too large, it may not completely repair the crack. Also, if the crack extends into the clear portion of the lens they that will show after the process has been completed.
- I cannot repair any broken plastic "hooks" on the housings that clip onto the lenses, but it doesn't matter much as the sealant used to reassemble them will hold it together.
- I can also repair the housing lower mounts for about $10 unless they are totally destroyed.
- when they're finished I'll follow up with another message and provide a total for the work and shipping. PayPal is accepted.
Turn around time will vary depending on weather and my schedule (I am retired and like to go camping).
The price for restoration of a set of tail lamps, if shipped with the housings, is $325. If I am shipped only the lenses then the amount will be $275. If interested, please send me a PM. That way I'll receive an email alerting me to your message. Don't plan on monitoring this post to check for updates.
[This message has been edited by gtoformula (edited 03-20-2023).]
