Here is the link to the ad with pictures of the 85 for anyone interested:
https://oklahomacity.craigs...o-se/6875991043.htmlAnd here is the link to the 84 parts car (with the black panels from the 85 car?):
https://oklahomacity.craigs...ents/6876019349.html You're really going to want to keep your comments and pictures in one thread so potential buyers here on PFF can keep up instead of hunting down several threads or new ones every time you repost it. I will be in the market for a car in a month or two so I've been keeping an eye out on local cars that pop up to get a feel for the market. I think you may be a bit on the high end for a car that's in different colors and missing some trim bits but I've been out of the market a while so I'm not really sure what's worth what these days. As I said in your last thread I'm in Tulsa and could be interested if you still have the car in a month or two.
I do have some questions that could help you sell it regardless:
1. How is the dash? Cracks? Are the corners by the vents by the doors broken up? It's a common problem so you may want to add a couple pictures.
2. Can you pull up the carpet in the trunk to get pictures of the corners by the frame rails? This is a common spot for the body to rust through and will indicate what kind of shape the frame is in under the body panels.
3. What's the story on the 2-tone colors? Did it start as an all-black 85 and then you swapped the red panels from your 84 parts car (that's listed in yet another thread)? Why? Did a tree fall on it? Was it damaged in a wreck? Were those body panels just in better shape? The black panels look OK in the pictures on your parts car listing so why did you swap them?
4. Front end damage can be hidden under the bumper as well. Can you pop the hood and take a couple pictures of the frame around the radiator supports?
5. How are the shift cables, rubber control arm bushings, engine mounts? Are the rubber/wear components dry-rotten or in good overall shape?
6. Has the timing set ever been replaced to your knowledge? I'm not super familiar with the 4cyl Duke but I hear the original timing sets had plastic gears that tend to fall apart.
7. Do the headlight motors work? Not a big deal if they don't but it would be one less thing to get it on the road.
8. What kind of shape is the battery tray in? They pretty much all rust but how far along is this one? It's probably worth taking a picture and adding it to your Craigslist ad.
9. What is the title situation on the (mostly) black 85 and your (mostly) red 84 parts car?
[This message has been edited by Alibi (edited 04-29-2019).]
