Please click on images to see larger version:
Front F40 transaxle bracket in Fiero.All of these brackets are made of 11gauge steel.I am also proud of the deep flanging.This flanging makes the final bracket stronger than 3/8 inch plate and more ridged.
This bracket was first made to fit this transmission.If it looks like it will fit good.If it doesn't another one is on the way.I have found over the years of making brackets. that G.M.has more than one casing for each transmission.Pix on the next F40 front bracket soon.
Front F40 transaxle bracket using O.E.M. Fiero mounts
Front F40 Bracket in unmodified subframe.All of these pix are in the same Fiero (cradle)
F40 rear transaxle bracket
3800 sc V6 motor mount bracket.Again made of 11 gauge steel with heavy flanging.
3800 sc V6 motor mount bracket.At least as strong as O,E.M.
3800 sc V6 motor mount bracket.Not shown is the multiple mounting holes,for either standard G.M.position or Fiero position.
Thelinsells@cox.net...all brackets shown are $100 each .The special bracket to mount intermediate shaft (SAAB) from F40 and 3800 is $150
[This message has been edited by thelinsells (edited 02-23-2019).]
