  The Mall
  3.4 DOHC LQ1 Swap extravaganza! Built engine, crate engine, exhaust, ECU, harness...
3.4 DOHC LQ1 Swap extravaganza! Built engine, crate engine, exhaust, ECU, harness... by msweldon
Started on: 01-27-2019 04:49 PM
Replies: 8 (1629 views)
Last post by: Internet-man on 05-12-2019 03:08 PM
msweldon
Report this Post01-27-2019 04:49 PM Click Here to See the Profile for msweldonSend a Private Message to msweldonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero 3.4 DOHC Plug and Play swap extravaganza....
For sale are two 96 LQ1 3.4 DOHC V6's and much much more... I'm not leaving fiero's just decided to go with a Turbo High Feature V6 and Saab F40 6spd.
One is a crate engine purchased off Ebay several years ago and kept in storage
Second is a rebuild of a 15K mile 1996 Crate by Ball Engines in Lilburn GA from pff user procarnut. Engine build sheet is available. My plan was to turbo the engine but it had a little too much blow by in the compression test so I chose to pull it and have it professionally rebuilt. Ball engines rebuilds 1000hp LS's to 1000hp 2JZGTEs. I had it rebuilt to accept boost of 13-17psi with appropriate ring gaps but stock compression was left alone to maintain off boost drivability. This is effectively the same build as Matt Hawkins performed to his 400hp LQ1 as well as lesson learned, i.e. SBC cam bearings, oil return porting, etc.. from Steven Snyder on his 220hp /DRIVE featured 88 Formula track car but with additional ARP head studs, balancing and much more, see below...
Build Details
ARP rod bolts
ARP head studs
.30 overbore
hot tanked
Hypereureticiceuretic Sealed power pistons (never could spell it much less say it right in public)
block casting removed to help oil returns.
tri metal clevite rod and main bearings
balanced rotating assembly
SBC cam bearings for Intermediate Shaft
polished crank
5 angle head job
clevite valves
MHI Lightweight lifters
custom short runner intake manifold
93/94 LQ1 cams as they are slightly more aggressive than the 96 model
LS1 throttle body
Full Custom harness with HPTuner tunable 97 Monte Carlo OBDII ECU with base tune from FieroAddiction
Custom Ceramic coated headers with 3" exhaust hi-flow CAT with test pipe with Flowmaster series 40 muffler (current setup does require trunk to be cut but could be modified back to stock placement)
88 and Pre 88 modified front engine mount with dodge truck mounts
Getrag 282 mounts with dodge truck mounts
Front engine mount with dodge truck mount
Dogbone mount to stock dogbone location
Pedal to Engine Throttle cable for LS TB
Custom aluminum underdrive pulley (spare NOS stock one as well)
LQ1 to fiero AC lines
Custom fuel lines to connect to stock fiero lines
New timing belt, idlers
New Alternator
New Water pump
New Oil pump
New ICM, acdelco plugs, and plug wires
Custom coolant lines
88 Neutral Flywheel
Also included
Fiero Getrag 282 with 160K miles
F23 with 80K miles
Two stock 96/97 LQ1 Intake Manifolds
One stock 96/97 LQ1 intake elbow and throttle body
Two LQ1 front valve covers
One set of stock 96/97 exhaust manifolds and crossover
Two NOS time chain tensioners
One complete Victor Reinze gasket set
One spare 96/97 timing belt
1997 Monte Carlo Factor service manuals
LQ1 Kent Moore Special Tool set
6 3800 Series II injectors (engine was running out of fuel at high rpm on the dyno)
Pre rebuild engine dyno'd at 218hp/189tq at the wheels with the included ECU.
The engine alone has $2500 into it.
Total package is 2800$
If purchased as a complete package a Haltech E11V2 with full harness will be included.
Please PM me with an questions....
[This message has been edited by msweldon (edited 01-31-2019).]
Total ratings: 463
Report this Post01-27-2019 07:10 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent...
Irrationable
Report this Post01-30-2019 11:43 AM Click Here to See the Profile for IrrationableSend a Private Message to IrrationableEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
msweldon
Report this Post01-30-2019 05:56 PM Click Here to See the Profile for msweldonSend a Private Message to msweldonEdit/Delete MessageReply w/QuoteDirect Link to This Post
forgot to add....updated list above with 4 laser cut stainless steel exhaust header flanges for fabricating custom headers.
[This message has been edited by msweldon (edited 01-30-2019).]
mrfiero
Total ratings: 150
Report this Post01-30-2019 09:01 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Man.....I have a crate LQ1 waiting for a Fiero to put it into, but if I wasn't 2000 miles away I would buy your stuff in a heartbeat! Great price for everything....GLWS!
Total ratings: 463
Report this Post01-31-2019 05:23 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Raydar:
PM sent...
Again...
msweldon
Report this Post01-31-2019 10:16 AM Click Here to See the Profile for msweldonSend a Private Message to msweldonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Again...
PM Replied
msweldon
Report this Post01-31-2019 10:25 AM Click Here to See the Profile for msweldonSend a Private Message to msweldonEdit/Delete MessageReply w/QuoteDirect Link to This Post
msweldon
Member since Sep 2000
Added dyno plot of engine before rebuild and a pic of one of the exhaust ports
Internet-man
Report this Post05-12-2019 03:08 PM Click Here to See the Profile for Internet-manSend a Private Message to Internet-manEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
