| quote | Originally posted by fierofrenzy:
Sorry I can't post pictures of those louvers on here. If it wasn't so difficult I would so you all can see them. I notice a lot of members mention the same about having difficulity posting pictures, while others post away. Whats up with that ? |
I've never understood the difficulty with PIP. It's clunky but effective.
Try this...
Take your photo and email it to yourself (or whatever method you use to get pics on your Windows computer).
Navigate to the folder containing your photo.
Right click your mouse on the file. On the drop down menu click on "Open with" and then "Paint"
The image will open in the Paint program.
(Different cameras will create larger files, depending on it's camera settings, so it is necessary to shrink the image to a size the PIP program can handle. Thats' why we are using Paint)
Without going into technical detail.....
Look at the image in Paint. If it fills your screen, or mostly fills your screen it's probably too big for PIP.
Somewhere in the upper left you should find a tool call "Resize". Click it and a new box will open.
Select "Percentage" and then enter 50 in the Horizontal and Vertical boxes. Click OK when done.
The picture should be visibly reduced by 50% on your screen
(50% is just a starting point for you to experiment with. You may have to make it more or less in order to get a size that is appropriate for the Pennocks page. Once you find the number that works for you it should work on your other pics. Just remember the % number)
Click File ----> Save (or Save As to rename it if you don't want to copy over the original image with a smaller version of it)
Make a note of where you saved the new image.
Open the PIP program.
Click "Browse"
On the new window go to where the image is saved.
Left click on the file to select it and then click "Open", which on my computer is in the bottom right of the window.
If you get a "Warning: Posting Rule Violation" message your image is still too big. Go back to Paint and resize again.
If the image shows up in the PIP "Preview" window you are ready to post your image.
Click the "Post It" button on the PIP window and you will see the file upload progress bar.
When you see the "Upload Successful" message left click your mouse button to place the cursor in the desired position of your text posting.
Then right click your mouse and click "Paste"
The file will appear in your posting looking something like this...
images.fieroforum.com/2017/RRR123_11(4)_2.jpg]http://images.fieroforum.co...7/RRR123_11
You have just uploaded your image. Click the "Preview" button at the bottom of your Pennocks message screen to make sure it uploaded correctly and to check how the image size fits the screen. If it is too big it will be larger than can be seen fully without requiring the viewer to scroll sideways to see the whole thing and it changes topic window size to accommodate it. (I find that personally very annoying)
If it looks good click "Submit" at the bottom and you are done.
There you have it. I hope this works for you. Let us know.
[This message has been edited by Rsvl-Rider (edited 12-07-2018).]
