I am in search of some stock Fiero manual transmission CV axles; preferably the shorter driver's side axle - but I can use specific parts from the inboard tripot end that plugs into the transmission from the passenger's side axle as well.
If you have a stock Fiero manual trans passenger's side CV axle that is damaged / has a bad outer joint - I can use it as long as the inner joint (the part that plugs into the transmission) is still good.
PM's or emails welcome.
More is more. Less is not enough.
