I recently upgraded to a racing intake, so I have no use for the Trueleo intake. It was custom made to fit a Buick GN throttle body. I made a custom throttle cable bracket, so the stock V6 throttle cable could work with the Buick throttle body. I also had to make a new intake hose, and modify the air cleaner canister to make everything work together. And I modified the base of the air cleaner canister, to increase its airflow capacity. Plus I had a custom vacuum distribution block made for the throttle body, to eliminate the need for vacuum ports sticking out the side of the intake manifold.
This Trueleo intake doesn't have any provision for EGR. And the throttle body doesn't have ported vacuum (only manifold vacuum). Just FYI.
I cleaned up all the parts and repainted them. The throttle body is painted with silver engine block paint. Everything else is painted with black POR-15. The finish is not what I would consider "show car pretty". So if you plan on using this on a show car, you may need to put some more work into the appearance.
I'm also including some extras, to save you the trouble of tracking down the parts yourself. Included is a new Fel-Pro manifold gasket, new air filter canister gaskets from Rodney Dickman, a new Fram air filter, a new IAC valve, and a used but good TPS. The throttle body gasket is already installed. The only thing missing is the MAT sensor.
Here are some photos:
Asking price is $550 shipped to anywhere in the USA. No international shipping. I prefer Paypal or money order for payment. If you're interested, please send me an email.
Happy Memorial Day weekend!
