  The Mall
  WCF 12" Corvette Rotor Brake Kit - w/ Adapters and Rings
WCF 12" Corvette Rotor Brake Kit - w/ Adapters and Rings by qwikgta
Started on: 12-09-2017 12:15 PM
Replies: 8 (853 views)
Last post by: pokeyfiero on 03-18-2018 07:57 PM
qwikgta
Total ratings: 84
Report this Post12-09-2017 12:15 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
other thread was getting no traction b/c the title was all jacked up. new thread same info.
WCF 12" brake kit. This kit from WCF is approx $580 shipped to your door, I only want $300 (plus shipping). This is the "full kit" which includes 4 adapters, 4 hub-centric rings and 4 vented 12" Corvette C-4 rotors. The rotors are used on the Chevrolet Corvette C4. They are re-drilled to the Fiero 5 x 100 bolt pattern. Also this kit comes with mounting bolts. WCF claims this brake upgrade will increase your stopping power by 20% better than the stock 1988 brake system, while still using the stock 1988 front and rear calipers and hubs. This brake system will not fit the stock 15 inch wheels. The larger 16 or 17 inch wheels will have to be used with this brake rotor upgrade. The stock 88 calipers and brake lines are used w/ this kit. This kit has approx 6,000 miles on it. I upgraded to 13" brakes, so this is now for sale. The rotors are heavy so local pickup is best. if not, i may have to box up the rotors into two box's to save shipping cost.
https://westcoastfiero.com/...stock-fiero-calipers
[This message has been edited by qwikgta (edited 12-10-2017).]
rotarycraig
Report this Post12-10-2017 06:19 AM Click Here to See the Profile for rotarycraigSend a Private Message to rotarycraigEdit/Delete MessageReply w/QuoteDirect Link to This Post
GLWS
qwikgta
Total ratings: 84
Report this Post12-13-2017 11:21 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
qwikgta
Total ratings: 84
Report this Post01-07-2018 09:10 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
qwikgta
Total ratings: 84
Report this Post01-13-2018 05:27 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
qwikgta
Total ratings: 84
Report this Post01-13-2018 10:57 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
qwikgta
Member since Jan 2001
bump
pokeyfiero
Total ratings: 309
Report this Post03-16-2018 09:55 PM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Status???
I need those.
qwikgta
Total ratings: 84
Report this Post03-17-2018 02:40 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
still for sale.
Rob
pokeyfiero
Total ratings: 309
Report this Post03-18-2018 07:57 PM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by qwikgta:
still for sale.
Rob
OK thanks. Going to pass. I'll PM you.
