I am selling parts for a 1987 fiero 2.5 iron duke motor and some other things for it CHEAP!!I bought the car for hopes of fixing a knock I thought was the lifters. I was wrong after buying hundreds in new parts for the motor. Motor ran when pulled I gave up and swapping it so im selling these parts to help fund the swap many are brand new parts just put on the motor in the last few months to fix the noise but didn't work. they are basically brand new with most having boxes and receipts. EVERYTHING ON THE CRADLE IS FOR SALE EXCEPT THE CRADLE SPINDLES AND CONTROL ARMS ASK FOR PRICES.
Parts and prices
Rear bumper:$150
Drivers Side manual Door with mirror:$50
Rear Spoiler:$45
block:$100
Isuzu 5 speed manual transmission:$150
both shift cables:$100 ; $50 each
slave cylinder brand new:$10
Complete Engine Head with new push rods:$65
Brand new exhaust manifold with bolts and springs:$50
complete exhaust system with manifold mentioned above:$120
Brand new left front transmission mount with used rear and motor mount:$5
intake manifold:$50
Brand new lifters with receipt:$25
Brand new spark plug wire set with box and sparkplugs with receipt:$15
3 extra spark plug wire set used almost new all for:$5
ignition coils both:$10
O2 sensor:$3
Alternator with brackets:$20
AC compressor:$65
oil pan:$15
EGR valve:$20
oil dip stick tube:$15
toqure strut w/bracket: SOLD
Harmonic balancer:$30
radiator:$30
flywheel:$15
oil pump:$15
fuel injector:$20
timing cover:$10
water pump:$10
fuel pump:$5
PCM:$30
Idle Air Control Module:$40
[This message has been edited by jetfighterv (edited 01-23-2018).]
