I will make this short and sweet and directly to the point.
1988 Fiero Gt Fastback original cjb car as shown on the rpo codes on the driver side fender
60,xxx original miles on the car, clean AR title.
No rust in the trunk areas or anywhere else noticeable. Under the car looks brand new.
Originally from Little Rock AR, paint is faded pretty bad and has spent most of its life in a parking lot.
The car still has the original t tops and gaskets along with a NOS set or C&C T tops w/ new gaskets etc.
The bad. Please read carefully! I purchased this car from a young man with the intentions of restoring it until I found debris from rats whom ate alot of wiring components behind the dash.
As a result we went with a different approach with the car, plans were to do a complete honda K series engine / transmission swap from an Acura Rsx Type S since we already had a donor
car for all needed components including a complete harness from headlight to tail light. After measurements were made we decided to go ahead and complete the swap with the acura
interior as well since the dash measurements were .75" in difference. Now that you have read that, understand that currently the car has absolutely no interior or cabin wiring, its all been removed.
All electrical has been cut at the firewell. Also, no ENGINE or TRANSMISSION and if you have guessed, no engine harness either.
In a nut shell, heres whats for grabs. A clean title 88 gt with 60,xxx miles on the body thats an original cjb car with factory t tops and seals still in tact. Included, a NOS pair of C&C t tops that have never been installed on a fiero before along with new seals and gaskets. Outside of the car being a rolling shell heres a list of the valuable parts that you are getting as a buyer: 2 sets of t tops, a 88 rear cradle and front suspension, 88 brakes that aren't seized up, good driprails, stiff steering rack, 88 headlamp motors, 88 front hub assemblies, rust free gas tank. The list goes on.
Located in West Tennessee, Thanks. I do not have a set price in mind however I would like to sell as a whole package.
https://imgur.com/zb11Hvhhttps://imgur.com/gsi7AH1https://imgur.com/7YMTbEYhttps://imgur.com/9TlxRi8https://imgur.com/Cz6uIrBhttps://imgur.com/898ZTZJhttps://imgur.com/xrbeVRHhttps://imgur.com/11Tinnvhttps://imgur.com/5eIPZP8https://imgur.com/gYXEAeC
