If your talking about this one, here's details where I fixed mine
My drivers side inner door handle broke a few days ago. While searching the forum, many were saying to remove the door panel to do this repair.
Found just by removing the black trim gave plenty of room to do the repair. Tools used, small phillips screwdriver, drill w/ small bit, rivet tool & rivets. Drilled out the rivet & removed the assembly, took 5 minutes.
The Doorman replacement handle (from autozone) did not have the bracket used to screw the trim on to. I drilled out the two rivets & riveted the bracket to the new latch assembly.
I was worried when it happened, thought it would be a nightmare to fix. Turned out to be an easy repair.
