Picked up a project a few months ago, purchased almost everything to finish it, and now need to make some room in the shop.
The car started its life as an 87 4cyl 5spd car. The previous owner picked up a low mileage (don't know exact mileage) 3800 S/C series 2, and a f23 Transmission. (I have a second trans for it as well) Proceeded to mount it in the car using a mix of mounts that he purchased and made. All of which look good. (This was his 7th swap, he has done 4.9's and 3800s before) He started the wiring and never finished it before the township told him the car had to go. So I picked the car up, with just the 3800 mounted in the car. The exhaust is a single out through factory location.
What the car needs now; Fuel lines need to be run Coolant lines to to be run Spark plug wires Coil pack mount Battery wiring / mount Engine Grounds C500 connector needs wired (all wires in the car ready to be wired) Computer needs Flashed Drivers side rear caliper Headlights Reinstalled (I can included Embrace Racing Flushmount kit if paid asking price, which is why headlights were removed) Vacuum lines figured out
Parts I am including: Extra Transmission Fuel Lines (AN fittings) Coolant Hoses and fittings) New c500 connector with pins Battery Terminals
So to get the car running you need pay for; Getting computer Flashed Plug wires and a coil pack mount Driver side rear brake caliper Vacuum Lines
Everything else should be just labor and is included. If you have questions let me know.
