3800 turbo setup
Ran best of 10.007 and 138.82 MPH at 3130lbs on drag radials with stock heads and ST1 Cam. Spools quickly and is very street friendly. Does require removal of the lower section of the trunk and the charge piping went through part of the upper section as I had it laid out, however with some creativity that could be avoided. Will require a L36 or L26 intake manifold and northstar throttle body, or you can replace the last elbow to adapt to different size throttle body.
Will include:
ZZP powerlog front manifold
Wrapped crossover with heatshield reinstalled on top of wrap
ZZP ported rear manifold with EGR block and modified for 4 bolt outlet to adapter
Custom built stainless turbo adapter from manifold to turbo with wastegate output.
Precision SP6262 turbo with T3 0.82 turbine housing
Extra T3 0.63 turbine housing for quicker spool
Precision 46mm wastegate with springs
Wastegate dump pipe
2 exhaust downpipes, one 4” race pipe with no muffler, one 3” with muffler
Very little power difference between them but much quieter with muffler
Either pipe ends up exiting out right side exhaust notch on GT bumper
Various cold side pipes, couplers, reducers and clamps
Tial Bov with 2 springs
LT1 MAF sensor and silicone elbow with 4” outlet for throttle body
Stainless braided Aeroquip 4an oil pressure lines and external oil filter adapter for turbo
Stainless braided 10an oil drain line and return line to oil pan
Exa-pump scavenge pump and bracket to return turbo oil to engine
Oil pan with return bung welded above oil level.
Air filter
I do not have a good intercooler as mine leaks internally putting water into the airstream. A ebay intercooler with 3” inlet and outlet is cheap and will work or a Precision PT1001 as I was using can be purchased from many sources. Water tank, pump and lines are not included.
Will be working on removing all remaining parts that are still on the car in the next week or so and will supply final pics once everything is off. Pictures of setup can be seen in my photobucket. Feel free to ask questions if interested.
http://s1181.photobucket.co...library/fiero%20picsLooking for $2300 US plus shipping
10.007 @ 135.54MPH. <-- Video
Best 60' 1.42
Best mph 137.66
Billet 6262 Precision turbo, PT1001 intercooler, ST1 cam, 140lb springs, comp pushrods, HV3, stock L32 bottom end and heads.
Old M90 XP Cam time -
11.425 @115.60
1.543 60'
