  The Mall
  Moving sale!
Moving sale! by kwagner
Started on: 01-08-2017 03:58 PM
Replies: 0 (367 views)
Last post by: kwagner on 01-08-2017 03:58 PM
kwagner
Total ratings: 62
Report this Post01-08-2017 03:58 PM Click Here to See the Profile for kwagnerClick Here to visit kwagner's HomePageSend a Private Message to kwagnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
*** LOCAL PICKUP ONLY. WILL NOT SHIP. ***
I'm moving in less than a month and I have an excess of fiero inventory!
I'd rather it go to someone and serve a purpose than me just toss it in the trash, so pretty much everything is cheap or free.
All you need to do is come pick it up!
Anything not gone within a couple weeks will be tossed.
Things that are here as of this posting but may not by the time you get here:
2 sets of rear vents
1 set of headlights
aero nose
racing seats
hood
decklid
2x sunroof glass
sail panel
left and right front fenders
left and right stock side 'scoop' areas
kyb shocks and struts
2x front springs
headlight bulbs
1 set fuel injectors
intake manifold gasket set
gatorback timing belt
inner right steer arm
2x speakers
heater core
recall tube
antenna
hood prop
dash blanking panel
thermostat
2x ashtray
door lock
light switch
ECM
2x relays
2x rear springs
4cyl intake manifold
rad hose
dogbone
heat shield
seatbelt
distributor
MAP sensor
oil sensor
stering column
GT bumper
water pump
4cyl exh man
alternator
rad neck
steering wheel
2x manual windows
clutch
2x 4cyl throttle body
VDO exhaust temp gauge
Give me a couple bucks and anything on the above list is yours. How's that for a deal?
Things that are/might be for sale for the right price but not part of the above:
88 formula, 5spd, 97 3800 sc 240rwhp dyno tested, corvette rotors, 17" wheels, koni shocks/struts
$5000ish, not really for sale yet but if you're dead set on it we can talk
- comes with:
- extra racing seats and brackets
- extra tires (set of falken azenis and some 'slicks')
- 99 alternator and bracket to install (needs hardware)
- set of manuals
IMSA getrag transmission
$2000ish
- as far as I know, never used in IMSA (spare).
- straight cut gears, LSD. untested (never got it in the car).
- comes with:
- a box of extra webster gears to make your own ratios
- extra aluminum quick change plate
HHP 84-87 competition adjustable swaybars (front and rear)
$1000ish
- never installed (got an 88 after purchse)
offenhauser intake manifold with 4150 carb
$500ish
- never installed (sold the 4cyl race car)
super duty valve cover
$100ish
- used some before selling 4cyl car
hooker super competition 4cyl header
$50ish
nearly new set of 4 stock tires and wheels (tech style)
$200ish
[This message has been edited by kwagner (edited 01-08-2017).]
