  The Mall
  For Sale: 1988 Pontiac Mera serial number 8102
For Sale: 1988 Pontiac Mera serial number 8102 by classic_cars
Started on: 09-24-2016 08:37 PM
Replies: 23 (2401 views)
Last post by: classic_cars on 10-06-2016 10:25 PM
classic_cars
Report this Post09-24-2016 08:37 PM Click Here to See the Profile for classic_carsSend a Private Message to classic_carsEdit/Delete MessageReply w/QuoteDirect Link to This Post
1988 Pontiac Mera
VIN: 1G2PE1190JP217614
58,375 miles
Salvage rebuilt title
2.8L, V6, 5-speed manual
Medium Beechwood interior
Power windows
Power door locks
Cruse Control
Tilt
Pontiac AM/FM/CD with equalizer and line-in
Power antenna
Power leather Recaro seats
Design Giugiaro leather steering wheel
K&N air filter
Dual trumpet air horns (Fiamm?)
(4) new General Altima HP tires (205/ 60 R15 front, 215/ 60 R15 rear)
1 1/2” rear wheel spacers
New lug nuts with McGard wheel locks
New cross drilled front brake rotors
(4) new brake hoses
(2) new brake calipers
Flushed brake fluid
Ported stock exhaust manifolds
New exhaust manifold studs
New headpipe, bolts, springs and muffler (new cat included but not installed)
New exhaust manifold gaskets
New RD Mera tailpipes
New RD EGR tube and SS exhaust hangers
New distributor
New coil
New distributor cap
New rotor
New plugs
New oxygen sensor
New idle air control valve
New MAP sensor
A/C hoses/ lines were replaced due to a kink
New receiver/ dryer
RD 308 Euro Design front bumper
RD sport shifter
RD Ferrari intake plate
New Vitaloni Baby Tornado mirrors
Heads were recently removed for a broken exhaust bolt. Cooling system was thoroughly flushed. All new gaskets on the top end including head gaskets.
Coolant tubes are arrow straight
Several new cooling hoses
Replaced rear trailing arm, lateral trailing arm and rear toe link
Car was lowered about 2”. (front end is sitting on the bump stops)
True-line track bar
Longer front sway bar end links
Included but not installed:
Used lower rocker panels- require prep and paint
New RD shift cables
Asking $10,000
Fly into Charlotte, NC and drive it home.
Also available is a Series II 3800 with machined flywheel, Fiero mounts, custom fuel rails, braided fuel lines, low mount alternator bracket, donor wiring harness, (2) ECU’s, ECU mount. New starter and alternator.
Pictures to follow.
steve308
Total ratings: 57
Report this Post09-25-2016 01:39 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by steve308 (edited 09-25-2016).]
classic_cars
Report this Post09-25-2016 03:54 PM Click Here to See the Profile for classic_carsSend a Private Message to classic_carsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Service Parts Identification decoded:
1G2PE1190JP217614
AAA-Coating on the glass
AR9-Seat ,front bucket, driver, passenger manual reclining
AU3-Power door locks
A01-Window, deep tinted all, Soft Ray
A31- Window electrical control
BC8-Front door map pocket RH and LH (available only with A31)
CD4-Wiper system, pulse
C60-Air conditioner, front, manual controls
D34- Mirror, visor vanity
D7V-Gear, speedometer driven
D80- Extension,rear end panel (spoiler-rear deck lid)
E5Z-Speedo Gears Less Adapter
E9Y-Vehicle Speed Sensor
E9Z-Speedometer Gears Less Keys
FX8-Transaxle, final drive, 3.61 ratio
K34-Cruise control
K60-Alternator, 100 ampere
L44-Engine, 2.8L V6 (Hi Output)
MG2-Transmission, manual, 5 speed (Muncie) 3.61 ratio
MM5-Transmission, manual, 5 speed, provisions (85-88)
NA5-Emission system, federal requirements
N33-Steering column, tilt type
N36-Steering wheel, rally 4 spoke (86-87)
PB4-Lock kit, aluminum wheel
PHO-Wheel, 15x6 front, 15x7 rear, diamond honeycomb
PON- Pontiac Assembly Plant
TR9-Lamp group, courtesy consists of;
UX1-ETR AM/FM stereo with clock, cassette, auto rev, search, replay, seek & scan (85-88)
U25-Rear compartment lamp
U29-Instrument panel, courtesy
U66-Speaker system, 4 dual front dash mounted,dual extended range, package shelf/quarter
V73-Vehicle statement
WS6-Performance package, special
WV9-Package, value leader (84-86)
W66-Formula option (88)
XEM-Tires, Goodyear Eagle GT+4 P205/60R15BSW STL (front) (88)
YLM-P215/60 R15 BSW (Rear) W/P205/60 R15 BSW STL (front) (86-88)
1SC-Option group #3 (1988) AIL,N33,CD4,C60,TR9,D34,K34,AU3
19P-Wheel color Black
4OU-White, U (upper of two tone)
6RD-Left front spring code
66B-Pallex cloth, Med. Beechwood
66I-Interior color, Medium beechwood
669-
7RD-Right front spring code
8UC-Left rear spring code
9UC-right rear spring code
BC/CC-
WA-8554- Fisher WA Paint color
U4OU-
66B-Pallax cloth, Med. Beechwood
classic_cars
Report this Post09-25-2016 04:27 PM Click Here to See the Profile for classic_carsSend a Private Message to classic_carsEdit/Delete MessageReply w/QuoteDirect Link to This Post
classic_cars
Member since May 2012
typhoon
Report this Post09-27-2016 06:32 PM Click Here to See the Profile for typhoonSend a Private Message to typhoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
mmmmm. $10,000 and a salvage title??
hnthomps
Total ratings: 51
Report this Post09-27-2016 08:38 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am temped to drive to Charlotte and look at the vehicle since it is only about 100 miles from me. However, I still think that it is overpriced for what it is (especially with a salvage title).
Nelson
hnthomps
Total ratings: 51
Report this Post09-27-2016 08:40 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
hnthomps
Member since Jul 2003
PM sent
Nelson
[This message has been edited by hnthomps (edited 09-27-2016).]
classic_cars
Report this Post09-27-2016 08:57 PM Click Here to See the Profile for classic_carsSend a Private Message to classic_carsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Nelson,
PM replied to.
classic_cars
Report this Post09-27-2016 09:41 PM Click Here to See the Profile for classic_carsSend a Private Message to classic_carsEdit/Delete MessageReply w/QuoteDirect Link to This Post
classic_cars
Typhoon,
Yes it is a salvage title. Car slid off the road and tore up the passengers side front quarter fiberglass. Does the insurance company want to fix it? No way. Does that depreciate the value? Yes- a little bit. Damage is to the fiberglass only. A full front clip is available and simply bolts on if you don't have fiberglass repair experience. (a Corvette or boat guy can repair it)
I displayed the car this past weekend at the Charlotte AutoFair. It got tons of looks- even with the minor front clip damage. Wish I had $1 for every picture that was taken of it.
Cars are a hobby for me. This is my 3rd Fiero. I've spent many hours restoring this car to it's original glory. Everything works and it runs and drives great. Where it goes next is up to the new owner. (Remove the Ferrari badges and make it a true Mera or drop in an L67 and make it perform like a real 308)
The car is worth what the market will bear. I've been very transparent and posted over a hundred hi-res pictures of the car.
It's not for everyone.
Thanks for looking!
Monkeyman
Total ratings: 182
Report this Post09-27-2016 10:44 PM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's a lot of body damage. I really like the seats and steering wheel. Do you know the model numbers? Where did you get them?
amflyer
Report this Post09-28-2016 08:00 AM Click Here to See the Profile for amflyerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would not pay that much for a Mera that has been wrecked. Professionally fixed or not
1984 Indy Pace Car\1988 Formula Custom\1986 turbo GT
Founder of Mason Dixon Fiero Owners Group
NYFOC Member
classic_cars
Report this Post09-28-2016 08:13 AM Click Here to See the Profile for classic_carsSend a Private Message to classic_carsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Seats and steering wheel were on the car when I got it.
$10,000 is the asking price. Most everything in life is negotiable.
Thanks for the interest!
classic_cars
Report this Post09-30-2016 08:39 AM Click Here to See the Profile for classic_carsSend a Private Message to classic_carsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 403
Report this Post10-01-2016 12:35 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's too bad you don't have all the Mera badges
The damage wouldn't be that hard to fix but it's not stock
Good luck with your sale it's a nice car
classic_cars
Report this Post10-01-2016 10:02 PM Click Here to See the Profile for classic_carsSend a Private Message to classic_carsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mara badges are easy to replicate. http://www.billetbadges.com can reproduce the front bumper badge. M E R A letters for the trunk lid can be cut from a GRAND AM SE.
At one point I thought about going the MERA route. I have a set of Fiero seats ready for recovering along with a Formula steering wheel.
I also have a spare Fiero hood to bond to a new hood. (reproduction fiberglass parts are available. I have a contact who claims to have a set of the original MERA molds)
I'll include whatever parts I have with the purchase.
classic_cars
Report this Post10-01-2016 10:03 PM Click Here to See the Profile for classic_carsSend a Private Message to classic_carsEdit/Delete MessageReply w/QuoteDirect Link to This Post
classic_cars
MERA too...
hnthomps
Total ratings: 51
Report this Post10-04-2016 08:35 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
For what it is worth, the Grand AM SE letters are in very short supply. Between John and myself, most of the available ones were purchased a couple of years ago. I have not looked recently so maybe some more have surfaced. The Billet Badges people do good work but I do not remember seeing ant MERA nose badges from them. One of our PFF members had some 87 and 88 reproduction nose badges made but they were all sold to the best of my knowledge. Some of the badges were fairly accurate and others were not. I still have one original 87 nose badge but would like to figure out how to polish the existing badge and use it after repainting an 87 Mera.
Nelson
hnthomps
Total ratings: 51
Report this Post10-04-2016 08:37 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
hnthomps
It is my understanding that Ferrari staff witnessed the destruction of the original Mera molds but maybe there was another set stored somewhere else.
Nelson
TXOPIE
Report this Post10-05-2016 12:37 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just FYI...EVM_Rob recreated the molds and will sells them.
TXOPIE
Report this Post10-06-2016 10:30 AM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is the parts you need:
http://dallas.craigslist.or.../ptd/5812383233.html
[This message has been edited by TXOPIE (edited 10-06-2016).]
hnthomps
Total ratings: 51
Report this Post10-06-2016 10:57 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
That may be correct but there are/may be some differences in sizing for specific components. As an example, Rob sent me the base for a tail light lens and the OEM Mera lenses will not fit on his base.
Nelson
Total ratings: 458
Report this Post10-06-2016 11:37 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Parting out '88 Pontiac Fiero GT (West Dallas)
classic_cars
Report this Post10-06-2016 10:23 PM Click Here to See the Profile for classic_carsSend a Private Message to classic_carsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello,
Grand AM badges are included with the sale.
ppnfm-5812383233@sale.craigslist.org
Thanks!
classic_cars
Report this Post10-06-2016 10:25 PM Click Here to See the Profile for classic_carsSend a Private Message to classic_carsEdit/Delete MessageReply w/QuoteDirect Link to This Post
classic_cars
Meant to paste this:
Thanks!
