  The Mall
  Power Mirrors Switch
Power Mirrors Switch by Spadesluck
Started on: 08-15-2016 10:22 PM
Replies: 4 (219 views)
Last post by: darbysan on 09-01-2016 10:48 AM
Spadesluck
Report this Post08-15-2016 10:22 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking for a power mirror switch. Thanks
mendesfrank23
Report this Post08-30-2016 10:00 PM Click Here to See the Profile for mendesfrank23Send a Private Message to mendesfrank23Edit/Delete MessageReply w/QuoteDirect Link to This Post
i may have one
mendesfrank23@gmail.com
send me a picture of one and i will look
jb1
Report this Post08-31-2016 03:51 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am pretty sure I have one, , it will be this weekend before I can check only problem it is in a box of parts and not 100% sure if condition,,
(series II swap in progress)
85GT Northstar/ 4t80e
Northstar Rebuild
Spadesluck
Report this Post08-31-2016 11:20 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys but I do not need it anymore. I decided to go a different route. I am using an F-body power mirror switch and mounting it in the middle similar to the old one. I purchased a new switch console to make this work.
darbysan
Report this Post09-01-2016 10:48 AM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just finished using an F-body switch on mine. You can mount the guts of the new switch in the stock switch housing ( they are identical)- you just have to remove a small metal "nut" that holds the 4-way switch part, and re-attach into the old switch plate. When you take the floating switch part off, pay attention to the orientation of the arrows on the back of the switch- they are important!. A little fiddly, but works perfectly.
[This message has been edited by darbysan (edited 09-01-2016).]
