I'm looking to buy a 3800 exhaust that requires no trunk cutting, I tried making my own and basically wasted $150 so now I'm going to bite the bullet and buy a pre-fabed one. Show me what you have and a price, I'd prefer something moderately loud but not so loud it will get me pulled over every 5 minutes.
You need to checkout member "Fierorog". I bought some 3800 mounts from him in January this year and he said the trunk friendly 3800 exhaust was coming soon.
I want mine to take the conventional 2.8 flow path but what he has in mind won't so my search goes on.
Spoon
A while ago Fierorog was talking about offering a prefab 3800 swap exhaust but I do not believe that he carried through on it. I do not believe that anyone makes what you need but if you can find someone just to make the head pipe the rest is easy. All that is needed for a no cut 3800 exhaust is an exhaust flange, a 90* 3" pipe, a tight U -bend, a crossflow muffler and two 90* exhaust pipes. A direct fit exhaust will not be quiet but you can achieve an acceptable tone with a Spintech crossflow muffler. If you use 3" in with dual 2 1/2" outlets it won't be deafening but loud. With dual 2" outlets it will be lower, with Heddman resonator dual tips, it will be lower still. Beyond that insulating the underside of the deck lid and engine compartment will quiet it some. Some have reported good results by wrapping the exhaust system but I believe that this also expedites rust and erosion.
WCF headers are well made, look nice and priced over $1,000 but have been shown to produce less horsepower than the makeshift exhausts that members have made up, especially when the free flowing ZZ powerlog manifold has been added.
I built two exhaust systems, the first for my 88GT 3800SC conversion and I used the magnaflow camaro V8 version suggested many times on Pennocks with a very tight u-bend, then two direct outlets with no trunk cutting required. The sound is not loud but a low rumble. On my sons 87GT 3800SC conversion, we installed the spintek muffler and it is a bit raspier, but he likes it that way. It also is smaller than the magnaflow and fit easier within the rear space of the 87GT frame. I completely wrapped the entire exhaust on his 87GT and it worked well to keep the internal heat down. We also kept his trunk blower in service and made a modified outlet piece to direct the air straight down over the new exhaust piping which has worked out well.
[This message has been edited by Curtisk1060 (edited 07-27-2016).]
Sounds good but the OP is looking for a pre-fab 3800SC exhaust that fits without trunk cutting. Many of us have built our own exhaust systems but I would believe that the op is at least looking for a downpipe/headpipe assembly with the tight U-Bend to the muffler. If he has that component the rest of the exhaust is a piece of cake. I say buy a 90* bend and the tight radius U bend. Measure up, mark everything and take it to a welder to assemble . The rest can be done with a saw 90* bends, clamps, hangars and clamp on tips..
Yes, if could get the tight U bend I'd be golden, I can weld it all up in just don't want to waste more money on messing it up, plus my chop saw blade is getting short on life so the less cutting i can do the better.I don't have access to all of my welding classes welders anymore or the machine shop so I'm stuck with my 110v flux core mig welder.
[This message has been edited by moodATM (edited 07-27-2016).]
I was going to do the same and I ordered all the parts from summit racing. As far as I know there are no kits. After doing a dry fit, I decided to cut out part of the trunk for 2 reasons.
1. The room between the trunk and engine is very tight making the fab difficult. 2. Heat retention. I felt the whole engine compartment would be cooler this way
I would say that you are correct that the direct fit exhaust is a very tight fit and a tedious fab job. I was able to get mine installed while even keeping the trunk heat shield so it can be done. Have not experienced any problems with heat as the new exhaust is smaller, non-restrictive and doesn't run around the engine as in stock configuration. When the Fiero is in motion, you'd be surprised how much air moves up through the engine compartment and out through the engine vents. One thing for sure though, a 3800 exhaust will be much easier to build with the lower half of the trunk removed but some people need to have a full trunk. On weekend trips to car shows with my wife, she doesn't travel light. If there was enough room she'd have a dozen suitcases with her.
Just want to give a quick thumbs-up to Dennis. One of the first guys to reply to questions, and takes the time to give detailed responses with examples. Nice effort to help those of us who are not mechanically inclined...
