Front end structural piece needed by lou_dias
Started on : 07-08-2016 09:07 AM
Replies : 9 (219 views)
Last post by : bonaduce on 07-09-2016 04:39 PM
Jul 8th, 2016
lou_dias Member Posts: 5396 From: Warwick, RI Registered: Jun 2000
I need the structure that's bolted to the front of the Fiero that the hood hinges bolt to. I believe it's the same structure that the air seal at the base of the hood is mounted to. Not even sure what this part is called so it's hard to search for it online. It spans most of the width of the car. Thanks!
09:07 AM
olejoedad Member Posts: 19994 From: Back home again in Indiana Registered: May 2004
Lou, the hinges bolt to the top of the front horns of the space frame. The attachment structure is welded as part of the space frame, not bolted on.
09:45 AM
Well, then I guess I need someone to cut that and ship it to my body shop to finish fixing up my mess...
11:21 AM
bonaduce Member Posts: 1590 From: witness protection Registered: Oct 2002
lou, I can send a pic later today, will be cutting my 86 apart this Monday dan
02:09 PM
Nebiros88 Member Posts: 1394 From: Nampa, Idaho Registered: Apr 2003
Sorry to butt in but I am also in the process of redoing a front end. Where are the best places to cut that most people use?
02:25 PM
FieroG97J Member Posts: 1479 From: Carriere, Mississippi Registered: Jul 2000
Check with the Fiero Factory in Huntsville. They replaced the front frame horns and all the metal up to the front of the tub and I could not see how they did it. I think they subbed out the job.
03:36 PM
quote Originally posted by bonaduce: lou, I can send a pic later today, will be cutting my 86 apart this Monday dan
is it fairly rust free?
03:54 PM
Jul 9th, 2016
lou, pics sent to the email on file (returned saying email invalid)
dan
[This message has been edited by bonaduce (edited 07-09-2016).]
06:54 AM
quote Originally posted by bonaduce: lou, pics sent to the email on file (returned saying email invalid) dan
The email with this forum may no longer be valid, use: LOUDFIERO@GMAIL.COM
04:24 PM
just resent, hopefully went through dan
04:39 PM
