]Hi guys. Since I wasn't able to sell my car as a whole I am gonna try to part it out. Just about everything is a or best offer item. I have a hard time posting pictures here, so if you are interested in something, pm with either your email or phone number and I can send you pictures.
T-tops, all the pieces are there,but the end caps are cracked. $600 O.B.O(SOLD)
V8 Archie Madcurl widebody kit. 95% done. $3500 O.B.O (SOLD)
V8 Archie aluminum radiator. $250
SC3800 cam its on the level of a xpz, I do have a cam card for it, about 20,000 miles. $150 O.B.O
CP forged pistons .10 over 20,000 miles $150 O.B.O
comp cams push rods. $50
3800 heads, they do have some port work. Have been told the port work is not the greatest.$175. O.B.O
rollmaster timing chain 20,000 miles. $75
4t65hd tranny. hardened input output shaft, hardened oil shaft, 3.29 gearing. about 20,000 miles. $700 O.B.O
3000 stall convertor. $125 O.B.O
axles for the swap. $75
87-88 headlight harness and motors with module. $125(SOLD)
ZZP HV3 insert $85
Ls1 throttle body $60
LQ4 maf. $40
#60 Deka Injectors . $150
ZZP fuel logs. $200 O.B.O (SOLD)
ZZP mini AFC fuel controller. $60
88 rear cradle, plus conversion kit for 84-87 with coil overs and new poly bushings. $325 O.B.O
Masterpower turbo T3T4 70t. $300 O.B.O
Tial blowoff valve. $175
Tial mv wastegate 38mm. $175
Strut tower brace. $75 O.B.O (SOLD)
Treadstone Intercooler. Core 7.8x22x3.5 over all length 27.5, 2.5 inlet/outlet 500hp efficient.$150. O.B.O
Older set of Mr MIkes Seats. black with yellow piping and stitching. $200 O.B.O
Racetronix fuel pump G75 255l. $50
Stainless steel magnaflow muffler single in and out. $75 O.B.O
GT tail lights. They are tinted. $250 [SOLD]
84-87 Intrax lowering springs $100
[This message has been edited by yellow fever (edited 05-06-2016).]
