  The Mall
  Need: 3800 Series 1 throttle body
Need: 3800 Series 1 throttle body by darbysan
Started on: 03-06-2016 10:57 AM
Replies: 2 (115 views)
Last post by: darbysan on 03-07-2016 11:19 AM
darbysan
Report this Post03-06-2016 10:57 AM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
NO LONGER NEEDED.
Looking for a specific throttle body for my conversion, and thought I would check here ( someone may have something that might work). My research indicates that MAYBE a Supercharged Throttle Body from a 94-95 Park Ave, 94-95 Bonneville, 94-95 Olds 98 or '95 Olds 88 should match the gasket pattern of my donor, but will have the throttle cables running toward the driver's fenderwell. I'm installing a 95 Riviera L67, and the throttle cables run toward the trunk. This means the throttle cable is 2 ' short. Swapping the throttle body should allow the stock V6 cable to reach.
I have a solution to extend my throttle cable, but a change in the throttle body would be a little more "elegant".
'87 GT in process, including GA / Seville brakes, Poly Suspension, '95 3800 Series 1 SC ( 225 hp ) 4t60e.
[This message has been edited by darbysan (edited 03-07-2016).]
Supracoupe
Report this Post03-06-2016 09:26 PM Click Here to See the Profile for SupracoupeSend a Private Message to SupracoupeEdit/Delete MessageReply w/QuoteDirect Link to This Post
For what it's worth wy car was swapped with a Series I 3800 from a 92 buick Park Avenue. The PO who did the install had to extend the cable to get it to reach.
darbysan
Report this Post03-07-2016 11:19 AM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I Bit the bullet and bought a new cable. Cancel post.
Thanks
