  The Mall
  programmed 7730 ECM with digital egr adapter plate
programmed 7730 ECM with digital egr adapter plate by MulletproofMonk
Started on: 02-26-2016 12:13 PM
Replies: 9 (442 views)
Last post by: MulletproofMonk on 03-29-2016 10:44 AM
MulletproofMonk
Total ratings: 78
Report this Post02-26-2016 12:13 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
MulletproofMonk
Total ratings: 78
Report this Post03-11-2016 08:58 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
MulletproofMonk
Total ratings: 78
Report this Post03-25-2016 05:43 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
dajack761
Report this Post03-28-2016 08:15 AM Click Here to See the Profile for dajack761Send a Private Message to dajack761Edit/Delete MessageReply w/QuoteDirect Link to This Post
you have a pm sir!
KMFDMFAN
Report this Post03-28-2016 10:30 AM Click Here to See the Profile for KMFDMFANSend a Private Message to KMFDMFANEdit/Delete MessageReply w/QuoteDirect Link to This Post
DANG! I think I really want this but have a question(s)...
Seeing as a 7730 ECM is better (faster processing?) does it require a digital EGR? Does the 7730 handle the old vacuum EGR?
Also guessing this is a Plug-N-Play set up?
Thanks
MulletproofMonk
Total ratings: 78
Report this Post03-28-2016 01:49 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
This is as close to plug-n-play as you are going to get. I built the adapter so that I could go back to the stock ECM if there was a issue that I needed to troubleshoot.
It is programmed for the digital EGR. Not sure how it will act if you use the OEM EGR setup. To me the whole point was to have the faster read, digital EGR, and the 4,000 PPM from the 7730 ECM to hookup my Heads Up Display...
dajack761
Report this Post03-29-2016 08:53 AM Click Here to See the Profile for dajack761Send a Private Message to dajack761Edit/Delete MessageReply w/QuoteDirect Link to This Post
Payment sent!
MulletproofMonk
Total ratings: 78
Report this Post03-29-2016 10:38 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I should also note that your engine should be in good running order before doing the 7730 ECM. Because it reads faster it actually amplifies any issues. That is why I used the adapter to go back to stock if necessary...
dajack761
Report this Post03-29-2016 10:41 AM Click Here to See the Profile for dajack761Send a Private Message to dajack761Edit/Delete MessageReply w/QuoteDirect Link to This Post
pm replied
MulletproofMonk
Total ratings: 78
Report this Post03-29-2016 10:44 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sold.
