  The Mall
  Comp Cams Valve Springs 3.4L. 3.1L/2.8L FOR SALE
Comp Cams Valve Springs 3.4L. 3.1L/2.8L FOR SALE by Dennis LaGrua
Started on: 01-04-2016 02:45 PM
Replies: 4 (349 views)
Last post by: f85gtron on 04-19-2016 06:50 AM
Report this Post01-04-2016 02:45 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is an extra set of 12 Comp Cams 980-12 quality valve springs that I am clearing out.. These will work on a 3.4L/3.1L/2.8L 60* V6 with a modified or stock cam. These were the ones recommended for my 3.4L turbo application. They are outer springs with an inner dampener spring. Direct fit without modifications. The set is brand New in the box. Lowest price in the country $29 + $5 shipping ( lower 48 ) pay pal accepted
PM if interested
[This message has been edited by Dennis LaGrua (edited 01-05-2016).]
Total ratings: 463
Report this Post01-04-2016 10:48 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dennis,
Asking on behalf of the "modders" out there. Will these springs work with a Crane H272 cam (.454/.480 lift), without additional head work for spring clearance?
Asking because stock (and most other "single" springs) require machining so that the coils won't bind at full lift.
Good price.
Report this Post01-05-2016 10:32 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Raydar:
Dennis,
Good price.
Just realized I had the wrong part number listed -corrected. They are 980-12 springs. I have used these springs with a 272 Comp Cam . It was a custom grind for a 3.4L turbo application but IIRC the lift was something like .440/460. The lope with that cam is very noticable. So lets add a caveot. For 90% of all PRACTICAL street strip applications these springs should accomodate any 60* V6 cam that can be used. No valve spring can be used as a direct fit with every single camshaft made plus if you decide to put a .480 lift 272 cam in your 60* V6 good luck with the ECM handling it and kiss goodbye to smooth running emissions and mileage.
Total ratings: 463
Report this Post01-09-2016 10:21 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
... if you decide to put a .480 lift 272 cam in your 60* V6 good luck with the ECM handling it and kiss goodbye to smooth running emissions and mileage.
My built up 3.4 with a Crane H272 ran really well. Felt like it had almost as much power as my 4.9. (This was with headers, a Trueleo intake and 800 worth of head work.)
It had a nice thump to the idle, but passed emissions every time, running a nearly stock tune, but with 19 lb injectors. It did run a little rich with those injectors, but nothing the ECM couldn't compensate for.
Edit -
From Summit...
Installed Height (in): 1.700 in.
Open Height (in): 1.250 in. (.45 lift)
Coil Bind Height (in): 1.150 in. (.55 lift)
Seat Pressure at Installed Height (lbs): 92 lbs.
Open Pressure (lbs): 230 lbs
Looks like they won't coil bind with an H272, but it exceeds "open height" spec for even an H260.
[This message has been edited by Raydar (edited 01-09-2016).]
f85gtron
Report this Post04-19-2016 06:50 AM Click Here to See the Profile for f85gtronSend a Private Message to f85gtronEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent
