  The Mall
  2003 Olds Aurora Complete engine
2003 Olds Aurora Complete engine by Fast Red
Started on: 11-07-2015 03:22 PM
Replies: 2 (290 views)
Last post by: mr_corean on 11-08-2015 03:54 AM
Fast Red
Report this Post11-07-2015 03:22 PM Click Here to See the Profile for Fast RedSend a Private Message to Fast RedEdit/Delete MessageReply w/QuoteDirect Link to This Post
For Sale is a 2003 built aurora engine turbocharged with eight Weber throttle bodies. The engine has approximately 5000 mi on it. The engine was built in 2010 after several years of construction. The engine red lines at 7000 RPM with over 500 HP. We have the boost set at 12 LB at this time. This assembly is designed for a 1984-87 Fiero. The list below is included with / in the engine.
Ross forged pistons
Eagle custom rods
Cometic custom head gaskets
Head studs
Modified crank
Custom cams by Engle
Weber throttle bodies with injectors
Complete turbo system made with 316 L stainless steel including the 3 1/2 exhaust
The Turbo is a Split T 71 ball bearing .84 turbine housing .70 compressor housing. The turban wheel 64.5 MM compressor wheel is 60.5 MM
All the intake system with air cleaner
Water injection system
Clutch and flywheel Duel Disc
All the engine accessories with A/C
Delphi ECU with all the engine wiring to the Fiero
All of this is ready to bolt to your transmission
The Acura NSX complete transmission with axles and cradle is also available but only with the engine
The Engine output is in access of 500 HP we saw 500 HP at 5800 RPM. The Clayton dyno was at its full rating at 500 HP. We used the dyno only for tuning
The Engine with all accessories will cost 6000
The transmission with the cradle for the Fiero will cost 3000
The trans with cradle and engine 8000
Contact 13104874612
[/img]
fireboss
Total ratings: 58
Report this Post11-07-2015 11:08 PM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
mr_corean
Report this Post11-08-2015 03:54 AM Click Here to See the Profile for mr_coreanSend a Private Message to mr_coreanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I loved seeing your set up at the drive to Charleston. What are you putting in the ride instead?
