I'm considering selling my 87 GT - 3800SCII swap done about 13 years ago by FieroAddiction because I had a stroke about a year and a half ago and I'm not as capable as I once was. Otherwise I'd fix and keep it. This is an awesome car at a discount for someone that's capable.
The bad:
I recently slid off the road and while there is no body damage, the front crossmember was damaged and possibly other areas of the chassis due to a rock maybe the size of a basketball in the field. Car still runs and drives but the alignment is bad. Front passenger wheel hit a rock almost dead center in the wheel and cracked the wheel. It holds air for about 15 minutes, enough to move the car around. Local wheel repair shop said the wheel can be repaired for $250 over the phone. AC was never hooked up, but all components are in place. Just need lines made from the compressor to chassis. Interior has typical wear around center console, but seats are both good.
The good:
I have over $15k into this car, not including the original cost of the car Not leaking any fluids, runs and drives although the tire will not hold air for very long and the alignment is bad. Should probably be trailered Starts/runs/drives every time like a factory car. If it was not damaged recently I wouldn't hesitate to drive it across the country. No trouble lights on in the dash, speedometer & tachometer work as they should. Everything works as it should except for the AC as mentioned above. This car is a serious head-turner. Everywhere I went people always took notice and I've been asked if people could take pictures of it at gas stations, grocery stores, etc. It was showed at the 25th Anniversary show in Pontiac, MI & a few years at the Fiero show in Carlisle, PA. 3-stage pearl orange paint Cowl scoop on hood Wingless Gray GT interior It's an extremely clean swap done by FieroAddiction (Rockcrawl) 3800SCII engine - pulled from a 2000 Grand Prix GTP at 800 miles 350 estimated crank HP Runs low 13s at the track - would need to be retuned to run faster 30k miles on the swap and the engine had 800 miles on it when it went into the Fiero, 110k miles on the Fiero chassis/body 4T60-E HD transmission Custom-tuned ECU ZZPerformance 2" intercooler Intake machining done by ZZPerformance ZZPerformance fuel rails Billet aluminum intercooler coolant tank ZZPerformance modular 3.25" supercharger pulley Ford Cobra SVT Intercooler heat-exchanger mounted up front Full stainless exhaust with Catalytic converter and Dynomax muffler FieroAddiction pre-88 to 88 big brake conversion using 88 calipers and Corvette rotors Suspension Techniques lowering springs Poly cradle bushings Poly suspension bushings Replaced shocks/struts with KYBs MAS MGR 17"x7.5" wheels Inline tubes stainless steel parking brake cables Headlights rebuilt with Rodney Dickman kits last winter Sunfire tach with boost gauge (looks factory) No rips or tears in seats Clifford 2-way alarm with remote lock/unlock/start
Located in Emmaus, PA just South of Allentown, PA.
[This message has been edited by V8Dreamer (edited 12-12-2015).]
Great assortment of quality aftermarket parts and a nice well done engine. You probably put tons of money in this car but unfortunately a bent front cross member signals a bent frame. A bent frame usually means that the car has been totaled. Further inspection may reveal otherwise but you may actually be selling a swap powertrain with a parts car. The package obviously has value, was well built, and would make a great project for someone to build upon a sound frame. I guess that final price will be determined by demand. Good luck selling it and very sorry to hear that your accident and heath has caused your departure from the hobby.
If I had the time and ability, I'd love to buy an 88 coupe for < $1k and swap everything, including the body to the more desirable 88. For someone that knows their way around Fieros, or cars in general, this wouldn't be very difficult, just time consuming. I, unfortunately, don't have that kind of time at this point so I'll let the buyer decide whether to fix the existing chassis and alignment and have a very cool, fast cheap car or whether to go all out on an 88 chassis with coilovers, etc. It really depends on whether the buyer's goal is to have a pristine Fiero or a fast car that turns heads as cheap as possible. As I'm sure you're aware, nothing turns heads like one of these with nice paint & wheels (the exhaust tone doesn't hurt either :-) ).
If anyone wants a complete subframe for the front of this, I am parting mine out from my '88 Formula 3800SC swap thread that's up here. I could sell it complete with new shocks, lower ball joints, calipers and all or just the subframe for even less. Asking $350 (complete) plus shipping. You got a beautiful car here, bud. I hope it goes to a good home.
[This message has been edited by InfernoFox (edited 11-13-2015).]
Thanks for looking, Ryan
I am friends with a guy by the name of Wayne Renninger. He is located in Allentown not far from you . He has a shop, tons of Fiero parts and does repair work. I would bring the car to Wayne for an evaluation and if the damage is confined to the front cross member only he has the tools the know how to install a good used replacement part and he is honest and fair on price. If you can get the car fixed you may be in a better position to drive it or even keep it and have more fun with it. I know full well what goes into building a Fiero like this and fixing it will restore the full value. Call Wayne and ask him what he would charge to install a new front cross member. 1-610-797-0521 or war51@rcn.com Might be a good solution and you have little to lose. .
Originally posted by Thunderstruck GT: If (and it is a big IF) there is any frame work necessary, it would be minimal and at a minimal cost. Probably $300.00 or less.
I don't know. I would have thought the rack would be cracked and be leaking fluid, so maybe it isn't that bad... And I just pulled an 87 front crossmember...
I'm considering selling my 87 GT - 3800SCII swap done about 13 years ago by FieroAddiction because I had a stroke about a year and a half ago and I'm not as capable as I once was. Otherwise I'd fix and keep it. This is an awesome car at a discount for someone that's capable......
As an example here is text I copied from one website:
The benefits of Vehicle Escrow Both Buyers and Sellers benefit from using Escrow.com as a neutral third party to monitor and transact the exchange of payment and vehicle. Peace of mind for vehicle Sellers The Buyer sends the agreed upon payment to Escrow.com. After verifying funds, we alert the Seller to send the vehicle to the Buyer. Protected from fraudulent checks and money order scams, the Seller has peace of mind knowing funds are behind the Escrow.com shield. Confidence for vehicle Buyers We do not release the money to the Seller until the vehicle has been received and accepted by the Buyer. This provides online car buyers the opportunity to inspect the vehicle before sellers are paid.
My only concern would be that this is an "as-is" sale of a damaged vehicle. The whole inspection thing could be touchy unless it's minimal and very black and white. It still runs and drives, but is clearly damaged.
Too bad you are too far away from me for an up close inspection. If the space frame is not tweeked, it appears to be an easy fix. If it is it really wouldn't cost all that much to fix but it would be more labor intensive.
If you were closer that car would probably be in my shop right now because if I saw it I'm sure I'd own it.
[This message has been edited by Thunderstruck GT (edited 11-20-2015).]
Like all things, there are a few rules. 1. You pick it up. I don't have a truck or way to take it somewhere to ship it. I just don't have the strength to lift it anymore after my neck surgery. 2. I'm not going to strip it down, it comes complete. I don't have a lot of time to work on stuff so the time I have is going towards my last 3800sc swap. 3. If some buys it on CL, then it's sold.
[This message has been edited by MulletproofMonk (edited 11-20-2015).]
That is a sharp car... Believe I have seen that one at Carlisle before... Like others have stated,looks like front cradle could be dropped out,repair/replace those crushed coolant/a.c. tubes and you got yourself a winner.
Kudos to 'MulletproofMonk' for stepping up and offering the suspension. That's what makes this place so awesome..
I'm with 'thunderstruckGT' here.. If it was closer to me, I'd be too Damn tempted!
A friend of mine who is more knowledgeable than I looked the car over and he agreed that the best option is probably to buy a non-running Fiero that's nice and straight and swap everything (drivetrain, body, seats, instrument cluster, etc.) over to the other car. It's a time-consuming process but not overly complicated and it could save a lot of headaches. It really depends on your goals I guess. If you're just looking for a cool, fast cheap car I'm sure this one can be straightened or damaged pieces replaced. If I were to keep it long-term that's the route I'd go. An 87 auto coupe would be the simplest swap but an 88 coupe would be tempting too since you'd get the suspension upgrades. I didn't look very hard but I saw a seemingly clean non-running 88 coupe about an hour away for $1k so I'd imagine one could be had for $1k or less.
Things he pointed out:
The hood is maybe 1/2" raised at latch/rear. The hood still latches, just doesn't seat at the same height as the fenders in the rear I'm not sure if this is and adjustment issue, since the impact could have jarred the front mounts loose where they're slotted, or an indication of frame damage.
The passenger door is sticky. It's always been sticky but the hinges seem to be in decent shape and it seems worse now than I recall prior to the damage.
If someone is equally equally proficient at mechanical and bodywork skills, this car offers great potential to build something really good . Its got great quality in its engine and the body parts are nice. Its just a matter of finding the right buyer. Have you tried an ad on Craigs list?
Swapping everything over to another vehicle would be a foolish move and one only a novice would do. A few hours on a frame rack would cure any and all alignment issues.
On many of todays vehicles a 15 to 20 mph hit or good pothole creates even the slightest of structural damage. Does anyone think a newer car gets scrapped once its involved in a fender bender or major impact?
This car is one of the simplest fixes once a replacement crossmember is obtained.
My personal opinion.....
I think someone put the fear of God into the OP that the car will never be right again. I see this happen all the time, usually by people that really don't know much about collision repair and those people are 9 times out of 10, wrong.
As I mentioned, this is an easy repair.
I think the OP is making a big mistake here and one that down the road, he will regret. If he really enjoyed the car that much he'd get a few estimates from professional collision shops with capable frame technicians and get the car repaired.
[This message has been edited by Thunderstruck GT (edited 11-23-2015).]
If you're taking my post as negative I can assure you its not.
It sounds to me like the OP has put a lot of time, money and passion into his car and although right now he's hurting due to the loss, he still loves the car.
I think rather than sell it and regret selling it he should take a step back, think about it, have some "experts" look at it, get estimates and get it fixed.
I have inspected this car and discussed all of the repair options with the owner. Someone could certainly just replace the front crossmember, wheel, a few other parts and have a great car to drive, even without doing any frame work. That's a very realistic possibility, but it's not what he wants. The chassis is slightly bent, it could be pulled/straightened and probably even be good enough that most people wouldn't be able to tell from the top, but IMO it will be difficult to get all the panel gaps perfect, especially with the non-existent adjustability of some of the body panels on a Fiero. My suggestion to him to swap the drivetrain and body to another chassis was based on having known him for 20 years and knowing what he wants in a car, and it's what I would do if I owned the car. That's what it will take to make the car perfect, and it comes with the added bonus of having an '88 under that beautiful paint. Or for $5000 plus a couple hundred in parts and easy labor you could have a nice car that lots of people would be happy to own. Either way, the car is a steal at this price.
Originally posted by Thunderstruck GT: Swapping everything over to another vehicle would be a foolish move and one only a novice would do.
Call me a novice and a fool. I have actually done it.
My wife and I both drive vehicles that were previously "totalled". I fixed both of them and several others before, including Fieros. What makes a Fiero different than most modern cars is the ability to swap the chassis without doing any paint work. If you really want to make the car "right", swapping the chassis is better than straightening a twisted one. It's lots more work and will almost certainly cost more, but the end result is better. I have nothing against straightening frames, but where there's a better option I'll take it. But I'm just a foolish novice, what do I know.
Jon aka rockcrawl aka FieroAddiction
[This message has been edited by rockcrawl (edited 11-23-2015).]
I have inspected this car and discussed all of the repair options with the owner. Someone could certainly just replace the front crossmember, wheel, a few other parts and have a great car to drive, even without doing any frame work. That's a very realistic possibility, but it's not what he wants. The chassis is slightly bent, it could be pulled/straightened and probably even be good enough that most people wouldn't be able to tell from the top, but IMO it will be difficult to get all the panel gaps perfect, especially with the non-existent adjustability of some of the body panels on a Fiero. My suggestion to him to swap the drivetrain and body to another chassis was based on having known him for 20 years and knowing what he wants in a car, and it's what I would do if I owned the car. That's what it will take to make the car perfect, and it comes with the added bonus of having an '88 under that beautiful paint. Or for $5000 plus a couple hundred in parts and easy labor you could have a nice car that lots of people would be happy to own. Either way, the car is a steal at this price. My wife and I both drive vehicles that were previously "totalled". I fixed both of them and several others before, including Fieros. What makes a Fiero different than most modern cars is the ability to swap the chassis without doing any paint work. If you really want to make the car "right", swapping the chassis is better than straightening a twisted one. It's lots more work and will almost certainly cost more, but the end result is better. I have nothing against straightening frames, but where there's a better option I'll take it. But I'm just a foolish novice, what do I know.
Good to see you back posting again Jon. Your knowledge and experiences with the Fiero helped alot of people over the years. I would like to respectfully disagree with you on one point. When steel is bent and/or twisted and straightened it will become work hardened and brittle. So if you straighten a frame its not the same as the way it was before. You have weakened it. Whether or not that loss of structural strength is enough to cause problems I cannot say. This car has many many good things about it but personally I would rebuild it on a sound frame/chassis. On a side note Fieros at Carlisle and MAFOA are going strong since the new leadership took over. We miss seeing your well done creations there.
Sale fell through. Car is still for sale. $5k firm. Since a few people asked, I'm serious about the firm part. I don't have to sell the car so I'm not willing to go any lower at this time. I'd like to sell it to a new owner who will appreciate it if possible but if I can't sell it I might just keep it and fix it.
looks like it was a nice car, sadly, even tho you are not a novice, you basicly saved me from a long drive.. As your post tells me, it's just a ready to go, 3800 cradle drop out to dump into another car.. for the guy that wants a sharp car that has a solid roller to dump it all into.. it's an option.. Sounds like it was a tad more than an easy slide off the road, if the space frame is tweaked that bad.. shame cause that's about what I'd put together and haven't because mine is an indy.. but for me, to get another as a for chassis swap it all then paint it, find a matching wheel, bummer.. hope he has good luck selling it, I'm sure it work for someone on here..
Congrats on the sale. Did it get sold to somebody on here? Just want to know if I should be expecting someone to come get my front crossmember before I lower the price...
For someone wanting to have an intercooled 3800SC Fiero and willing to do the transfer of all body parts and engine , at $4000, its a decent buy. Hope to see the rebirth of that car again at Carlisle in 2016.
