  The Mall
  3800 turbo parts needed
3800 turbo parts needed by Sirayden
Started on: 07-16-2015 07:09 PM
Replies: 4 (158 views)
Last post by: Sirayden on 07-18-2015 09:33 AM
Sirayden
Report this Post07-16-2015 07:09 PM Click Here to See the Profile for SiraydenSend a Private Message to SiraydenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Still need a few parts for my "budget build" so looking for good used stuff.
Need:
Modded retainers
130lb springs (or similar)
Upgraded pushrods, stock length
Re-usable rocker arm bolts
Double-thick timing cover gasket
Big degree wheel
Preload checker (need when using ls7 lifters?)
May need:
Map sensor for turbo boost over 20psi
New rod and main bolts which won't need machining
5/16-18x1" flywheel bolts (not a flex plate, will be manual trans)
Hp tuner
Alternator relocation bracket
98-99 Monte Carlo/Lumina Z34 engine harness
I realize some parts are for other vehicles but it doesn't hurt to check. Let me know what you have. Thanks!
Formula
Total ratings: 96
Report this Post07-17-2015 09:33 AM Click Here to See the Profile for FormulaSend a Private Message to FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have pac 130# springs I could sell. $90 shipped.
Sirayden
Report this Post07-17-2015 07:57 PM Click Here to See the Profile for SiraydenSend a Private Message to SiraydenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for replying! Do you know if those are PAC 1218 or 1518 springs? Or did you get them from ZZP, etc? How many miles on them?
Formula
Total ratings: 96
Report this Post07-18-2015 08:29 AM Click Here to See the Profile for FormulaSend a Private Message to FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
1218, they are from zzp, ~5000 miles. Switching to different heads that came with 150s.
3800 Turbo
Sirayden
Report this Post07-18-2015 09:33 AM Click Here to See the Profile for SiraydenSend a Private Message to SiraydenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, cool. Pm your paypal address and I'll send the money when I get home from work. Thanks
