  The Mall
  FS: Custom 1985 / 1988 Pontiac Fiero GT 3.4 Turbo 5-speed Custom Body
FS: Custom 1985 / 1988 Pontiac Fiero GT 3.4 Turbo 5-speed Custom Body by bluefiero
Started on: 06-17-2015 09:44 AM
Replies: 12 (1766 views)
Last post by: rlndhill on 01-24-2016 10:14 PM
bluefiero
Report this Post06-17-2015 09:44 AM Click Here to See the Profile for bluefieroSend a Private Message to bluefieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Long story short my father and I spent about 2.5 years building this car from the frame up. The car was stripped down to its bare frame and every aspect of the car was looked over and rebuilt or restored. The car only has ~10,000 miles on it from the rebuild. I then moved across the US for college and the car stayed back at home in storage. It's been in storage for about 5 years now and it's time to finally let go of it. I'm sure there are miscellaneous items i'm missing so i'll continue to update as I remember. Looking to get $4,000. I've also got a spare 5 speed Getrag tranny (28,xxx original miles), 4-speed tranny, and other miscellaneous parts. If you purchase the car you are welcome to have whatever spare parts you want to grab. The car was originally built N/A with intentions of turbocharging at a later date. I initially had a smaller turbo (.40/.48) on the car and decided to go bigger. The car has gone through about a dozen iterations through Sinister Performance for an initial tune on the smaller turbo. One winter I bought a rebuilt T3/T4 Hybrid .60/.63 turbo, as well as a new turbo specific camshaft too install, and get ready for when I was done with school the following summer, however, I ended up staying out of state so I never got around to coming back to the car to drive it. The larger turbo and camshaft are installed on the car currently and have less than 50 miles on them. The car DOES currently drive.
Pros
Engine/drivetrain
3.4L Camaro bottom end and heads
Fully blueprinted and balanced motor (stock compression) (10,000 miles on the rebuild)
Custom turbo kit with a newly rebuilt Garrett T3/T4 Hybrid .60/.63 turbo (<50 miles) (oil and water cooled)
Crane Cams 253901 H-260-2 cam. (<50 miles)
21lb injectors
SAAB intercooler with fan
HKS SSQV BOV
Adjustable fuel pressure regulator with gauge
Manual boost controller
Gasket matched port job on intake and exhaust
Darrell Morse big bore throttle body and intake plenum
Powder coated turbo, intake plenum, valve covers, etc.
'85 ECU with knock sensor
2 bar map sensor
Custom 2.5" exhaust with muffler, no cats
5-speed Getrag transmission
Spec Stage 3 clutch (10,000 miles)
ACCEL 10mm plug wires
MSD blaster coil
Body
1985 GT frame converted to 1988 GT fastback
Custom yellow paint job
Functional hood scoop
Functional decklid scoop
V8 archie quarter panel scoops
Quarter window scoops
Norms flushmount headlights
Carbon fiber wing paint matched
Custom chin spoiler
Front mount battery kit
Interior
Black and yellow painted interior
Blue glow gauges
A/F ratio gauge
Boost gauge
Custom installed 6x9 rear speakers
Upgraded front speakers
Upgraded stereo receiver
Black and yellow racing seats with 4 point racing harness
Black and yellow racing pedals
Black and yellow steering wheel
Full factory power options
Suspension
Full poly bushings all the way around
Wire brushed rebuilt and painted suspension components
Rebuilt calipers (10,000 miles)
Drilled/slotted rotors with pads (10,000 miles)
Coilovers (10,000 miles)
17" wheels with tires (10,000 miles)
Cons
The car has been sitting for about 5 years so it needs some TLC.
There are quite a few spots on the car when paint has peeled off and will need to be repaired.
The left door of the car is in primer as it was damaged in storage a couple years ago and will need to be repainted.
The chin spoiler will need to be repainted
The car has a pretty basic tune completed by Sinister Performance but will need to be dialed it a bit better. It is running very rich right now.
Car needs a new rear decklid lock
Minor surface rust in engine compartment from sitting for 5 years.
Let me know if you have any questions. The vehicle is located near Glendale Heights, IL.
In the Links below I've got some pictures from when it was finished building, as well as it's current condition. I've got plenty more pictures to send if anyone is interested in more.
Build Pictures
http://s20.photobucket.com/...uff/3_4%20Turbo%20GT
Current Condition
http://s20.photobucket.com/...t%20Condition%2085GT
[This message has been edited by bluefiero (edited 10-20-2015).]
bluefiero
Report this Post07-14-2015 08:27 AM Click Here to See the Profile for bluefieroSend a Private Message to bluefieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
bluefiero
Report this Post07-22-2015 10:28 AM Click Here to See the Profile for bluefieroSend a Private Message to bluefieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
TTT
Willing to entertain offers or motorcycle trade as well.
bluefiero
Report this Post08-24-2015 05:01 PM Click Here to See the Profile for bluefieroSend a Private Message to bluefieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
bluefiero
Report this Post08-28-2015 10:11 AM Click Here to See the Profile for bluefieroSend a Private Message to bluefieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
bluefiero
Report this Post10-20-2015 03:48 PM Click Here to See the Profile for bluefieroSend a Private Message to bluefieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
rice.1
Report this Post10-20-2015 07:48 PM Click Here to See the Profile for rice.1Send a Private Message to rice.1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice. Good luck with the sale!
ICouldaBeenAV8
From: Chatsworth, California; Clearwater, Florida, and Milwaukee, Wisc.
Report this Post10-20-2015 10:33 PM Click Here to See the Profile for ICouldaBeenAV8Send a Private Message to ICouldaBeenAV8Edit/Delete MessageReply w/QuoteDirect Link to This Post
How long did that paint last on the turbo?
bluefiero
Report this Post10-21-2015 06:49 PM Click Here to See the Profile for bluefieroSend a Private Message to bluefieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
The turbo was powdercoated and is still in great condition.
bluefiero
Report this Post12-02-2015 08:53 AM Click Here to See the Profile for bluefieroSend a Private Message to bluefieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fixed a few minor mechanical issues last week. Car is running great. Bump for anyone interested!
Rare87GT
Total ratings: 173
Report this Post12-02-2015 11:49 AM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can I buy the lexan covers off the headlights lol!!! I need a spare set
Best 1/4: 11.7 @ 115mph
Best 60ft: 1.60
bluefiero
Report this Post01-21-2016 08:14 AM Click Here to See the Profile for bluefieroSend a Private Message to bluefieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
$3,000. Any takers?
rlndhill
Report this Post01-24-2016 10:14 PM Click Here to See the Profile for rlndhillSend a Private Message to rlndhillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bluefiero you have a PM.
