It's a sad day. Some creep decided to blast a red light(yellow according to the good officer), and blasted me in the process. I was rebuilding it the long way, you know, a bit at a time. The paint still sucked, so did the interior. I was after the mechanicals first. So from Mr. Dickman, a shift kit, cables, and shifter, as well as the stainless vacuum lines. the 60x60 headlights from projector retorfit, rear suspension linkage from the fiero store, and a bunch of other stuff, like steering rack, and headlight motors, all new or rebuilt. The car is done, but most of that (except maybe the rear linkage) is ok. I can store the bits, and save for another 88 notchie, if they still exist, or I can let someone who can use the whole lot now have it. Otherwise it goes to scrap, as I can't afford to store it, or part it out. So if you're in the phoenix area, and can use the parts, let's make a deal. As I'm now out of this hobby, at least for a while, I also have an '85 GT in much abused shape that needs a good home, too. It used to be drivable, but has been in storage for a couple years time. I had it slated for an engine swap, since the previous owner let it sit with plain water in the coolant, and figured the engine was a loss. Not sure how many in Phoenix, but I'd rather see it go to use somewhere, than get crushed/scrapped. So here's the damage. I wanted to cry.
Hit so hard the drivers side bulged out.
So thankful there wasn't a passenger. They'd be dead, or hurt bad.
[This message has been edited by Cygnus (edited 04-21-2015).]
