I have a few sets of the SS fuel lines that came on transport vans. I'll include the compression fittings to attach these to your factory hard lines too. I have also cut the ends off and deburred the tubing so they are ready to be installed as easily as possible.
You pay shipping. (About $5)
PM me or post here. I'll send you my PayPal and go from there.
They are shipped and I sent PMs with the tracking info included. Thanks again.
I do have one more set that I was using on my own [88 / 5 speed Getrag / 3800SC2 / stock GTP exhaust manifold] Fiero for the past few years. They worked flawlessly, looked good and have never leaked. I'll send you the entire setup that will screw into the stock fuel filter if you want it. The only thing you should know is that I relocated my fuel filter to the driver's side of the car so that the coil packs could go where the stock filter used to be. Relocating the filter was easy. The stock line between the pump assembly and the filter is just flipped from right to left. I can send instructions with pictures if you need them, but you shouldn't. It was easy. I also modified my stock GTP fuel rail with a tubing bender so that the quick disconnect fittings point toward the stock Fiero air filter location. Like any of these, I doubt they will reach the fuel rail if you have an unmodified rail with the filter in the stock location. I'll sell these for $40 shipped. I'll even throw in a new set of compression fittings just in case the old ones don't want to seal up a second time.
I removed them when I built a set of AN fuel lines for my car.
[This message has been edited by 2002z28ssconv (edited 05-21-2015).]
