Unfortunately I need to sell my race car. I have been building it for the last 3 years. There are thousands of hours in this thing and over $30,000.00 invested!!! This car is built right, and with attention to detail. This car was built to road race but would also be a very good drag car.
I have listed most of the information on the car. If you have any questions please feel free to PM me. Thanks for looking. Hope this goes to a good home and someone can get the enjoyment out of it that I was hoping to.
More pics available upon request.
Contact: PM me...
Price: Best Offer (Motivated Seller, Need moved by winter)
Body:1986 GT Fastback Body
1985 GT Frame
Frame & Body gutted extensively… 2300-2400 lbs
New Paint Inside and out
Tilt Nose Piece by Norms Fiberglass
Tinted Sail Windows (Removable) by Kahines
LED Taillight Panel by Kahines
New rear quarter Panel scoops.
No-Mar Lexan Front and Rear Window, Also Sun Roof (All Removable)
Mustang Hood Scoop (On rear Deck)
Custom Splitter (Front) (Plywood underlayment)
Belly pan (Front)
Rear Deck Lid Hinged w/ Shock Struts
Interior:Custom Roll Cage (Nascar Style Door Bars)
New interior paint (Cage/Floor pan, Engine bay, & Cradle)
Custom Alum Dash (Covered with Carbon Fiber Looking Vinyl)
Alum console Cover (Covered with Carbon Fiber Looking Vinyl)
Aluminum Racing Steering wheel w/ quick release
5/8” Steel Steering Shaft supported by steering heims (OE Column Removed)
5 Point Harness
Window Net
4 Panel Rear view mirror
120 mph OE Gauge Cluster
Short shifter
Shifter Rebuilt w/ kit by Rodney
Hanging Race Dual MC Brake Pedal
Manual aftermarket gauges (Oil Pressure, Oil Temp, & Water Temp)
Engine: Will need gone through (Can explain further upon request)
3800 Series III (2004) newly built with best of everything.
Line Bore Checked
Decked to clean up
Forged & coated Diamond Pistons (8.5:1 Comp)
Total Seal (File-Fit) Rings
ARP Rod Bolts
ARP Main & Head Studs
Dbl Roller Timing Chain
Oil Pump Cover Machined Down
Yella Terra 1.9 Roller Rockers
Push Tubes (Oil Restricting)
160 Therm
New lifters
New Intense Racing Stg 1 Cam
New Harmonic Balancer
Heads magnafluxed and rebuilt.
Guides Checked
Valve Job
New Intense Valve Springs
All new balanced rotating assembly
Re-flashed PCM by Intense Racing and then remote tuned by
Brian Turner with Dyno Tune Motorsports
Spec Alum. Stage 4 Flywheel
Spec Stage 4, 6 Puck (Non-sprung) clutch
ZZP Exhaust Logs
Custom Baffle Gates in Oil Pan
3” Custom Exhaust (no mufflers)
N* Throttle Body
KN Air Filter
New Radiator Hoses
New Sensors (All)
Balance Shaft Removed
New Serpentine Belts
New Accel Racing Plug wires
Alum Blower Gasket
New Valve Cover Gaskets
New Exhaust Gaskets
New water pump
New Alternator
Blower was rebuilt (Re-greased needle bearings)
New Fluid in Snout
Transmission:5 spd Getrag
Clutch pedal rebuilt w/ kit by Rodney
Suspension:Front & Rear Suspension by HT (Arraut) Motorsports (A-arms, spindles, shocks, coil-overs, etc.)
Front A-Arm to A-Arm Support Strut (Custom)
Rear Strut Tower Support Strut (Custom)
New HHP Racing Sway Bars
Sway Bar Links by Rodney
Aluminum Cradle Bushings by Rodney
All Polyurethane Bushings
All new 7/16” wheel studs
Steering Rack Rebuilt with Rodney’s Rebuild Kit
Rear Bump Steer Kit by HT Motorsports
New ball joints
Brakes:Brake Ducts (Front & Rear)
Wilwood Dual Master Cylinders (Wilwood)
Brake Adjuster (Front to rear)
Wilwood 12” Rotors
Vented & Slotted Rotors
Wilwood Dynalite 4 Piston Calipers and new pads
Misc:3 Core Alum. Champion Radiator
Fuel Tank Pan/Guard (Aluminum)
Battery Box moved to RF
17” x 9” Enkie RFP1 Light Weight (15 lbs) Racing Wheels
5x4.5 (Mustang Pattern) (Brand New)
& Much much more. Very nice car, must see to appreciate…
Not Included:APR Carbon Fiber Adjustable Wing (Rear)
Racing Seat
More pics available upon request...
[This message has been edited by Fiero Racer 64 (edited 09-08-2016).]
