I don't sell anything, but having done this recently I can offer some advice. This is all assuming that you have an 84-87. I don't think Corvette calipers on an 88 are very common, the 88 calipers will work with bigger rotors as is with just some adapters. DoubleC4 sells both front and rear brackets for this setup, plus concentric rings. He has recently posted a sales thread,
DoubleC4 brakesHe also includes a howto link.
I didn't follow their advice for master cylinder or parking brake.
For Master Cylinder, I got one from a full size 94 Blazer w/vacuum boost. Just swap out reservoirs and it is a bolt in. Cheap and in stock at Rockauto or any parts store.
Parking brake cable solution I used is here -
Parking brake solutionJust make sure you get rear calipers with both brackets. Most of the remans have only the mounting bracket or none it all. There is a parking brake cable bracket you will also need. This setup is as close to bolt in as you can get and cheap too.
One issue I have is this really increases the front brake bias. I am investigating options to remedy this.
