3.4 dohc custom hot cams!!! by 3.1 88FieroGT
Started on : 10-18-2014 03:33 PM
Replies : 10 (583 views)
Last post by : 3.1 88FieroGT on 10-11-2016 10:40 PM
Oct 18th, 2014
3.1 88FieroGT Member Posts: 233 From: antigo, wi, usa Registered: Jun 2010
Entertaining offers for custom regrind cams for an 3.4 dohc lq1. These are the cams that where in Jeff's (fieromadman) n/a 1987 Fiero Gt which ran a 13.5 in the 1/4 mile which I do believe is a record for this engine n/a. Will also include the ecu and tune chip. Would also sell wiring harness for additional money. They are currently still in the cam carrier but can take them out to lower price. These are not cheap cams so I'll only entertain reasonable offers. Dyno'd at 250 hp and 244 torque.
Thanks Steve
Cal or text 715-219-2977
1/4 mile video
03:33 PM
gambler85 Member Posts: 292 From: dexter,mn,US Registered: Nov 2010
Pm'd u
08:13 PM
hookdonspeed Member Posts: 7980 From: baltimore, md Registered: May 2008
got specs? im going turbo, but sometimes a NA ground is still better then the stock. and being cams are rare to come by for these engines..
08:16 PM
They are the same specs as the SLR cams from Steve long
08:22 PM
Silicoan86 Member Posts: 1614 From: Savage, MN, USA Registered: May 2004
All the info on the cams including specs and dyno results (230 whp and 216 ft-lbs) are available in
this thread. Steve Long Racing still grinds these for $100 per cam.
[This message has been edited by Silicoan86 (edited 10-19-2014).]
09:23 PM
Oct 19th, 2014
msweldon Member Posts: 671 From: Georgia Registered: Sep 2000
what else did you do besides cams to reach the 250hp 244tq dyno run?
10:57 PM
Oct 20th, 2014
--180* t-stat, (cam degrees) 1.5 degree intake advance and 5 degree exhaust retard, ported lower intake, FFP pulley, A/C Idler, flowmaster exhaust, EGR delete, K&N filter, chip This was done prior to me buying the car. Hp and torque from the looks of it is at the flywheel not the wheels.
02:31 PM
Nov 16th, 2014
elitopr Member Posts: 236 From: Orlando Fl, Ponce, PR (USA) Registered: Dec 2006
Bumb... i need front exhaust manifold for a 97 3.4 DOHC...
10:35 PM
Oct 11th, 2016
bump still have this stuff
08:50 AM
Formula88 Member Posts: 53788 From: Raleigh NC Registered: Jan 2001
Just curious, is there any difference in the cams in the 92-95 engines and the 96+? I know the exhaust ports are drastically different.
11:26 AM
Not that I'm aware of heads are definitely different but I think cams are the same
10:40 PM
