Like I said... I have an 88 formula (white with beechwood interior) for sale. Its been sitting for way tooo long in my carport. The good... its all there... the bad.... I took it off the road and have the engine disconnected from the car ... and ready for removal , all that's left to do is remove the cradle bolts. The reason was low oil pressure on Idle. Im assuming its the main and rod bearings. OR could just be the gauge... the gauge looks like it was working while driving it... oil pressure was good.! its a 5 speed 2.8 of course. extras I believe is a sunroof... seats are in great shape.... some warping of the interior (typical) .. if there is real interest, I can upload pics and answer all questions... If you search my name, you will find the pics for this formula... Im not certain on rice yet....
this does come with the correct rims...the forth one has a flat tire, that's why the grey one is on the rear... it will be swapped out after its on your trailer.
I did notice that one of the wing stands will need to be replaced...
the engine is ready to be removed
front compartment bay... with wind deflector
[This message has been edited by fiero67 (edited 10-25-2014).]
I have always wanted this combo. Too bad its so far away.
1984 White Fiero Sport Coupe (Juliet) in restoration //www.fiero.nl/forum/Forum1/HTML/089093.html 1988 Red Fiero Standard Coupe (Bella) in restoration 1990 Black Buick Reatta (Noir) 2002 White Chevy Impala base(Haylie)
the underneath is almost rust free.... some light surface rust on the sway bar and the plugs on the floorboards..... and as far as the trunk is concerned.... there is rust on the passenger side (which is from the windstand leaking) I can post pics later this weekend
