  The Mall
  WTB: Torque Rods for Deck Lid w/ Wing
WTB: Torque Rods for Deck Lid w/ Wing by craigtbone
Started on: 09-18-2014 06:26 AM
Replies: 2 (185 views)
Last post by: gtxbullet on 09-19-2014 06:52 AM
craigtbone
Report this Post09-18-2014 06:26 AM Click Here to See the Profile for craigtboneSend a Private Message to craigtboneEdit/Delete MessageReply w/QuoteDirect Link to This Post
While repairing the damage caused by being rear-ended I decided to add a wing to my '88 Coupe. The original Deck Lid was plain, no wing or luggage carrier. The original rods are not strong enough to hold up the Deck Lid with wing.
So I need a set of Torque Rods marked with White (I believe) for a Deck Lid with a wing.
Craig T.
Fieroking
Total ratings: 78
Report this Post09-19-2014 02:37 AM Click Here to See the Profile for FierokingClick Here to visit Fieroking's HomePageSend a Private Message to FierokingEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can connect strap to the bottom of torque rod and ratchet it toward the read of the car to remove tension. Then pull the pin out. Then continue pulling the tension rod rearward then put the pin in either the middle or rear hole and remove the strap. Do the same on the other side any should me good to go.
Joe Sokol
85 SE Daily driver with a 3.4 DOHC OBD II
88 Formula/GT 4.9 Allante Intake (My Baby)
www.fieroking.com
gtxbullet
Report this Post09-19-2014 06:52 AM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
Joe Sokol
^grade A advise ;-) ^
