  The Mall
  LIQUIDATING EVERYTHING no more storing parts...make offers ASAP
LIQUIDATING EVERYTHING no more storing parts...make offers ASAP by gtxbullet
Started on: 09-17-2014 01:27 PM
Replies: 17 (818 views)
Last post by: gtxbullet on 10-07-2014 10:50 PM
gtxbullet
Report this Post09-17-2014 01:27 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
SOLD
F.I.E.R.O. - Fantastically Imaginative Engineering Racing Object
I'm here to Help, just ask
Tech/Mechanic (Restorations, Modifications, and Service)
1988 Base Coupe (the show car ;-) )
2003 GTP Daily Driver
Size 13 Feet with Cracking Ankles and Tired Knees
[This message has been edited by gtxbullet (edited 11-21-2021).]
Fastback-Ish
Report this Post09-17-2014 04:21 PM Click Here to See the Profile for Fastback-IshSend a Private Message to Fastback-IshEdit/Delete MessageReply w/QuoteDirect Link to This Post
88 front brake calipers?
gtxbullet
Report this Post09-17-2014 05:44 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
No.
Just have a pair of rear 84-87 calipers (cores/for rebuild)
ragging_fiero
Report this Post09-17-2014 08:59 PM Click Here to See the Profile for ragging_fieroSend a Private Message to ragging_fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would you might have poly mounts for an 88 GT? Also maybe a poly dogbone?
gtxbullet
Report this Post09-17-2014 09:30 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have stock v6 dogbone with bluish colored urethane bushings in it.
No pictures as it is packed in a bin under several bins. Id do $13 shipped in the usa. ($7 shipping and $5 for the part)
johnyrottin
Total ratings: 85
Report this Post09-18-2014 08:03 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am in need of a few parts:
Automatic shift bezel for the Rottinchop
Aux gages for the Rottinchop
Drivers side front marker light, round style for the GBCT
gtxbullet
Report this Post09-18-2014 10:52 AM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have some aux gauges.
There is an auto shifter faceplate but it is very worn. Not good enough for the Rottinchop ;-)
I have no markers for sale.
Let me check the gauges to make sure there are no issues.
Do you need gauges only? Or the housing, mounting bracket, etc? I don't have a spare harness or faceplate...
Price would be $20 shipped. Housing, working gauges, lense, screws, mounting bracket. If I can find a faceplate add $7.
jc8367
Report this Post09-18-2014 11:16 AM Click Here to See the Profile for jc8367Send a Private Message to jc8367Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
gtxbullet
Report this Post09-18-2014 11:37 AM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by jc8367:
PM sent
Didn't get a pm
johnyrottin
Total ratings: 85
Report this Post09-18-2014 02:10 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Only need the gage pack...no lens or housing or the metal bracket. We have all that. Gage just seems not to work correctly. Auto shift plate will be hydrodipped so as long as it is in good order (not broken) it is okay. Darn on the markers. I need to send the gages and shift plate up to Rob for the Rottinchop. let me know once you test them.
gtxbullet
Report this Post09-18-2014 02:53 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you don't need the doors on the shifter plate you can have it for free. If it will work for you great! If not then you can have one to give away
$20 shipped total.
[This message has been edited by gtxbullet (edited 09-18-2014).]
355Fiero
Report this Post09-18-2014 03:36 PM Click Here to See the Profile for 355FieroSend a Private Message to 355FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
'88 GT Gauge cluster or just the speedo buffer out of one?
Thanks
Don
gtxbullet
Report this Post09-19-2014 12:01 AM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
Don
Unfortunately no
gtxbullet
Report this Post10-07-2014 05:42 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump...
Going to finish my garage project this weekend and I have 19 bins and boxes of fiero parts PLUS a bunch of stuff in the attic that cant fit in my bins. Consoles, sail windows (coupe only), cables (only 1 set for a 4 speed), coupe rear notch clip, a bunch of factory spare tires, complete v6 top end and accesories (no heads), perfect if you want a 3.4L swap.
The list goes on.
storage for the last 2 years comes to nearly $1900...
Come pick up EVERYTHING (bins not included) for $500 cash. Ill help load.
johnyrottin
Total ratings: 85
Report this Post10-07-2014 08:53 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I need an auto shift bezel...
Bebbitt
Report this Post10-07-2014 09:25 PM Click Here to See the Profile for BebbittSend a Private Message to BebbittEdit/Delete MessageReply w/QuoteDirect Link to This Post
In need of ashe tray doors if you have them.
gtxbullet
Report this Post10-07-2014 10:49 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
I messaged you back.
I have 1 but has heavy wear. Not cracked.
One shifter boot tab is missing and what looks like a cigarette lighter melted area. $5.00 plus shipping No pictures.
Ash tray doors not included (it didnt have any).
gtxbullet
Report this Post10-07-2014 10:50 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
gtxbullet
Member since Apr 2008
$8.00 shipped for a set. No springs.
Ive PM'D my paypal
