I have an 86 SE that had a fastback transplant and some other body work done before I bought it. It developed a rod knock, yesterday, and I'm weighing my options. It's not my daily driver, and I have two Trans Ams as toys, so I'm not in any hurry. But I do want to figure out a way to either put it back on the road by spring for the least possible $, or whether anyone is interested in buying it off of me and I'll buy a V8 Fiero once I can afford one. Here are pics, so you get the idea of what my car is like:
https://www.flickr.com/phot...ts/72157646724533016It is my third Fiero (an Indy was my first car, and I had an 86GT in the late 90s.) I've had it less than a year. It has the following features:
Auto, ~80k miles (speedo flutters like crazy)
88 wheels, pretty good tires
Starts, runs, shifts, drives, stops, turns, etc
New LED side lights (from Danyel)
Sunroof, with deflector
Newly professionally tinted windows
New smoked sail panels
Stock color 88 yellow paint, base/clear, pretty good - nice and smooth, but not painted around the backs of panels etc
93 TA seats, nice
Interior is pretty clean (dark gray) - only the radio bezel is damaged
2.8 that was running great - just replaced all the ignition/distributor components
PO said it has a 'performance chip'
I put a new alternator in it in June
New embroidered yellow and gray matts (Lloyds)
LED bulbs in base/clear smoked tail lights
Pontiac CD with yellow aux in (from forum member)
Headlight motors are disconnected, I pulled the snap ring and have been just moving the arm off and onto the spindle manually on the rare occasion I drive at night
No significant rust anywhere that I've found
Integrated scoop rocker panels
Cold air intake
SO, these are the options as I see them:
1. Put a new long block in it or rebuild mine (myself or have someone do it)
2. Put the fully dressed 5k TPI 305 I have on a stand in my garage in there (instead of saving it in case one of my TA motors ever goes)
3. Buy a used 2.8, perhaps off of one of you (and install myself or have someone do it)
4. Put a 3800 or other V6 in there
5. Sell the car, buy another Fiero with built motor later (though I really, really want a yellow one)
6. Part it out (which I don't have time to do, and would break my heart)
I don't really need more power, I drive like an old man. But I do like the idea of it having a more modern powerplant. My wife would KILL ME, however, if I spent the kind of money that it looks like Archie charges to do a V8 swap (although I'm sure it's worth it.) $7k, right?
Any advice or things I should consider as I weigh these options? Anyone in the greater Grand Rapids, MI area that would be interested in rebuilding or swapping in a motor for me for at a reasonable cost? Anyone within driving distance have a bulletproof 2.8? Thanks in advance for thinking about this with me.
Re: knock, since I am not remotely a professional mechanic and am self diagnosing: The oil gauge has always fluttered, like most of my instruments - the light did come on when at idle at around 10psi. But it would shoot up to 50psi while driving, I assumed it was the gauge - I'm guessing now that it was actually too low and I smoked something in the lower end. It's run for a total of about 10 minutes since I heard the noise, pulling out of my driveway, then back into the barn and trying to diagnose. It was about 3 days after I replaced the distributor and coil and retimed etc. I also had a couple of plug wires that I noticed were split right about the same time, (which I've now replaced,) but I think that's all a coincidence. It had the same oil pressure after I put the distributor in as it had before I did. The sound is crazy rough - gets louder as you accelerate, and I can find nothing else that might be making that sound other than bearings or a rod.
[This message has been edited by philrenato (edited 08-30-2014).]
